Online Now [1593]:
Visitors: 1592
Today: 174013
Total: 149243954
Forums › The Car › 206 Problems › Strange Rev's Problem
MrrNoName
PostPosted: Tue Dec 28, 2010 9:12 am Up
Hi all, my pug has developed a revs fault.
when the revs are dropping they drop down normally (at a normal speed) untill they hit just above 2k. then they take a looong (3 seconds ish) time to drop from 2k to idle.
this happens both in gear and in neutral. also when then engine is hot and cold.
It makes it annoying to drive as its hard to match the revs when changing gear.
throught maybe it could be an air leak, but dont really know where to start looking.
the EML is not on. any help would be appreciated Smile
PostPosted: Tue Dec 28, 2010 9:39 am Up
What engine is it?
What year of 206?
These simple details about the car in question that a lot of people don't bother posting up actually help us work out the best advice to give to solve the problem.
MrrNoName
PostPosted: Tue Dec 28, 2010 9:49 am Up
haha i always usually put the details up, totally forgot this time, it was because i was in a rush. sorry Razz
2001 (Y) reg, pre plexed 1.4 LX
PostPosted: Tue Dec 28, 2010 9:51 am Up
Take the stepper motor out / idle control valve out, clean the plunger & also the air bypass hole the plunger fit in to ( use a cotton bud )
Normally 2 x torx 20 screws hold the stepper motor in, don't loose the O ring seal on the end & DON'T try & unscrew the plunger from the motor!
russman
PostPosted: Tue Dec 28, 2010 9:57 am Up
can you let me know if the above works for ya mate, i am almost starting to have the same problem..
Cheers
Thanks,\r\nRussell
PostPosted: Tue Dec 28, 2010 9:59 am Up
What year & engine is your 206?
MrrNoName
PostPosted: Tue Dec 28, 2010 11:09 am Up
not too sure what the stepper motor is or does tbh.
what would be best to clean them with?
PostPosted: Tue Dec 28, 2010 11:13 am Up
Stepper motor helps control the idle speed of the engine.
WD40, some paper towel & some cotton bud that you clean your ears with are all you really need to clean the plunger & the air bypass hole.
MrrNoName
PostPosted: Tue Dec 28, 2010 11:26 am Up
thanks for the info, is it easy to get too, where is it on here for example?
PostPosted: Tue Dec 28, 2010 11:36 am Up
Is that a picture of YOUR actual cars engine?
Cant really see from that picture, got one any closer up?
MrrNoName
PostPosted: Tue Dec 28, 2010 11:39 am Up
its not MY actual cars, mines identicle though
PostPosted: Tue Dec 28, 2010 11:45 am Up
Follow the throttle cable to where it links on to the throttle spindle / butterfly.
Look on the opposite side of where that linkage is & you should see the stepper motor.
Number 4 is what you are looking for.
MrrNoName
PostPosted: Wed Dec 29, 2010 3:35 am Up
thanks for the advice. i will have a go. anyone else got any ideas of what it could be if its not this ?
im a little unsure as it doesnt struggle once idleing. i.e the revs take a while to go down to idle but once they are at idle they run consistantly at the correct revs, every time. no stalling. no high idle etc. they just take longer to reach idle.
lee1973
PostPosted: Fri Feb 04, 2011 3:20 pm Up
I have got this same problem,the car has been stood up for a months and now it does this,can any one with a pic show me where this as MRbsi's pic isn't there.
lee
