Posted: Wed Dec 29, 2010 8:12 am |
abs06 wrote: |
thank you guys. i have to go to the peugeot garage in eastbourne to get a new washer pump so i will ask them about the BSI and driving lights while im their |
You will most likely find they:
Will have no idea about DRL's as its not UK standard spec.
Wont change the setting in the BSI configuration from the standard settings it rolled of the production line with.
Posted: Wed Dec 29, 2010 8:25 am |
Im multi plex ithink
| Abs
Peugeot 206 1.6 Sport (55)
Audi A1 2.0 TDi Sport (14) | |
Posted: Wed Dec 29, 2010 8:26 am |
abs06 wrote: |
Im multi plex ithink |
Yes your car is multiplexed.
Posted: Wed Dec 29, 2010 11:00 am |
MrBSI wrote: |
DRL's
The new Lexus rear lights |
But how long will it take them to realise?
Posted: Wed Dec 29, 2010 11:02 am |
Edward wrote: |
MrBSI wrote: |
DRL's
But how long will it take them to realise? |
EU forcing new cars to have them fitted is bad enough, just watch the death rates for cyclists, motorcyclists & pedestrians go up in the near future.
Posted: Wed Dec 29, 2010 11:03 am |
They need them from next year don't they?
Posted: Wed Dec 29, 2010 11:06 am |
Feb 2011 for DRL's
ESP from 2012, now that is an EU law I agree with
Posted: Wed Dec 29, 2010 12:17 pm |
MrBSI wrote: |
Might be a good test if someone with PPS & a multiplexed 206 gives it a try? |
I didnt know about this, good to know. Now need to find someone with PPS now
Posted: Wed Dec 29, 2010 12:19 pm |
All it will be will be dipped headlights and associated lights (numberplate lights/sidelights/rear lights) on permanently
| '98 MGF 1.8i
Team: ex-206 owner
Team: Roof is always down when it's not raining! | |
Posted: Wed Dec 29, 2010 12:29 pm |
I reckon it will be just the sidelight circuit powered up once the engine is running, no dipped headlights.
Only one way to find out, wait for someone to give there BSI a tweak & see
Posted: Wed Dec 29, 2010 1:00 pm |
Just wire the LED's into a ignition feed, then they'll come on when the ignition is on. And if you want them to go off when the dipped beam, use a 5 pin relay in the circuit.
You can't activate DRLs on a non-plexed with PP, I'll have to collar Rich and have a go on his 180 to have a look
Posted: Wed Dec 29, 2010 1:32 pm |
Lee wrote: |
Just wire the LED's into a ignition feed, then they'll come on when the ignition is on. And if you want them to go off when the dipped beam, use a 5 pin relay in the circuit. |
Do u have more information on where to find the ingnition feed and what 5pin relay would be best
| Abs
Posted: Wed Dec 29, 2010 1:35 pm |
Any ignition feed from the engine bay, fusebox, cabin loom would be sufficient.
Any 5 Pin 30/40amp automotive relay would do
Pin 30 = Goes to an ignition wire
Pin 85 = Would go to your positive feed on your dipped beam
Pin 86 = Would be your chassis earth
Pin 87 = would go to nothing
Pin 87a = Would go to your DRLs
Posted: Wed Dec 29, 2010 4:46 pm |
i have put the dlr strips inside my head lights and small ones above the grill. if look at pics of my car u will see wot i mean
Posted: Wed Dec 29, 2010 6:32 pm |
MrBSI wrote: |
Only one way to find out, wait for someone to give there BSI a tweak & see |
It will be dipped headlights on permanently. Trust me.
Some countries have dipped headlights on all the time by law - eg some Scandinavian countries for example. This setting will be to make this legal.
In the computer system on my dad's Merc C250 CDI, the Daytime Running Lights option just puts the dipped headlights on whenever the engine is running.
| '98 MGF 1.8i
Team: ex-206 owner
