Posted: Wed Dec 29, 2010 8:31 pm |
hello there, i hadnt driven the car for about 3 weeks and started it in the cold weather, started first time but there is a rattle that im sure wasnt there before. its horrible, does it even on idle and if you rev past 3 thousand rpm it is very loud and if you go to 4 it feels like the french bolts are going to pop our everywhare!
sounds like a piece of metal flapping about or something. would it be useful to post a video on youtube of it?
also the day i bought the car in september i paid 50 pounds to get the a/c regassed and it worked ice cold for a month or so, i then left the car for about 3 weeks and it just stopped working and when the a.c button was pressed you could hear a hissing noise but no cold air.
could the two problems be connected?
no loss of power or anything just sounds deadly. any help or commments would be very appreciated. thanks
| No diesel clatter no lap time smasher | |
Posted: Wed Dec 29, 2010 9:51 pm |
My air con stopped working as gas was low and a valve stops pump pulley from engaging to protect it I was told if it ran on low gas pump could fail and if not used it could fail due to seals no being lubricated, had ir recharged at Peugeot dealer £50 over a year ago and still working, I need it to demist screen it's that bad. Just wondered if your pump has that protection on pulley or pump making the noise.
| I don\'t feel old. I don\'t feel anything until noon. Then it\'s time for my nap. | |
Posted: Thu Dec 30, 2010 5:40 am |
| Contax wrote: |
| , I need it to demist screen it's that bad. |
Change the pollen filter
