Latest: jackrox1992
Overall: 17186
Online Now [625]:
Visitors: 624
Today: 68619
Total: 148233161
Forums › The Car › 206 Problems › warning signs
warning signs
darrenskinner1
PostPosted: Thu Dec 30, 2010 9:38 am Up
for some tie now, every now an again i start my car and every warning sign comes up, brake fault, airbag fail, esp fault, engine managment etc, it stays on for a while, maybe a couple o days later it goes away
any ideas?
PostPosted: Thu Dec 30, 2010 9:55 am Up
I would check the state of the battery, alternator charging out put & the connections.
Also try a BSI reboot.
PostPosted: Thu Dec 30, 2010 10:02 am Up
I thought every warning sign should come up when you start the car.
PostPosted: Thu Dec 30, 2010 10:04 am Up
Bet your oil pressure warning light doesn't come on Wink
PostPosted: Thu Dec 30, 2010 10:20 am Up
I suppose what I mean is that all the lights come up as a check when you turn the ignition on.
PostPosted: Thu Dec 30, 2010 10:27 am Up
They don't though.
Only certain warning lights come on at the pre start check Wink
darrenskinner1
PostPosted: Thu Dec 30, 2010 12:42 pm Up
yeah but after i start the car the are on, and the warnings come up on the centre consol, nah the oil pressure dont, when u start driving it takes about 3 m ins before the speedo will work aswell when this happens
PostPosted: Thu Dec 30, 2010 12:44 pm Up
Will be the battery dying and/or alternator under or overcharging
darrenskinner1
PostPosted: Thu Dec 30, 2010 1:23 pm Up
ok cool ill look into this Smile
sri16v
PostPosted: Fri Dec 31, 2010 6:26 am Up
Id get the battery checked first, my 180 would get the airbag faults when starting on very cold mornings, but they would clear if you turned it off and restarted it. New battery solved it for me.
2004 GTi 180
mjsroofing
PostPosted: Fri Dec 31, 2010 6:29 am Up
battery drained from start up and the alternator is then charging it back up and the lights then go off. at a guess and agreeing with above.
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
Ash
PostPosted: Fri Dec 31, 2010 6:30 am Up
MrBSI wrote:
They don't though.
www.youtube.com/watch?v=lzJL7_uzELs
