Latest: tbafonso
Overall: 17130
Online Now [250]:
Visitors: 250
Today: 16655
Total: 103878824
Forums › The Car › 206 Talk › Exhaust mounts?
Exhaust mounts?
jonny_fulton03
PostPosted: Thu Dec 30, 2010 7:47 am Up
Hey guys, i have a feeling the gearbox exhaust mount has gone on my car as there's a distinct sound of the exhaust hitting the body coming from that area. Ive rang peugeot and they inform me that the whole part of the exhast that the mount is attached to will need to be replaced. Is this correct? Just wanted to check first before i spent much money!! Joni.
PostPosted: Thu Dec 30, 2010 10:18 am Up
If the bracket has come off the exhaust it could be welded back on...but you are only delaying spending money replacing the rotten section it's fitted to.
Also don't go to the Peugeot dealer...they are possibly the most expensive place to buy such parts.
mjsroofing
PostPosted: Thu Dec 30, 2010 10:45 am Up
need pics really, if you were local i'd weld it for you, should be a quick job really, as above though only delaying a new exhaust, but hay the money is better of in you bank rather that theirs .
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
jonny_fulton03
PostPosted: Thu Dec 30, 2010 1:36 pm Up
none of the exhaust system is rotted at all. Its all fine and has bin changed in the last 2 years fully! im hoping its the downpipe mount as thats under warranty with motosave...lol Joni
