Posted: Fri Dec 31, 2010 7:55 am |
Hi,
Looking at getting one. I don't want a loud one at all. I want something subtle.
I am on the website but its difficult to work around. Anyway, how much are they going for brand new? Do you need to go to a store?
And a question I have always wanted to know, How can you tell how loud an exhaust is before you fit it?
JD
Posted: Fri Dec 31, 2010 8:11 am |
Are you after a full system or just the backbox?
Posted: Fri Dec 31, 2010 8:19 am |
I went to the nearest shop and told them how I wanted it to sound and then gave me a quote, he also said if it doesn't sound how you want come back and we will change it. Also lifetime garuntee
Bigger the pipe louder it will be.
Posted: Fri Dec 31, 2010 8:25 am |
| DJ- wrote: |
| Are you after a full system or just the backbox? |
Just the backbox.
Posted: Fri Dec 31, 2010 8:32 am |
Posted: Fri Dec 31, 2010 8:41 am |
I have a full powerflow system on my 180 sounds just right and any problems for as long as you own the car that will fix it free of charge.
| Image removed due to size
focus st 3 with pro alloy intercooler, 3" mongoose down pipe, 200 cell sports cat and mongoose cat back, collins bov, dreamscience dsci cold air intake,focus rs injectors,focus rs oil cooler,dreamscience dsci tuneing platform mod X map,focus rs clutch & flywheel, rs fuel pump, polly bushes in wish bones rear axal and suspension white line front and rear arb, eibach pro street s suspension. | |
I'd get an off the shelf system as they are higher quality generally.
Posted: Fri Dec 31, 2010 8:55 am |
| JDave wrote: |
| DJ- wrote: |
Just the backbox. |
No point using powerflow if you just want a backbox
Posted: Fri Dec 31, 2010 8:57 am |
i have a cat back system from powerflow, it has a nice tone to it but when you get a look at the pipework under the car it's not brilliant, it also set me back £340, i would probably go for janspeed if i was to ever replace it
| 2003 aegan blue gti 180 - CatCams 804's camshafts - CatCams vernier pulley - R.S.Tuning remap
Gti 180 Project Thread | |
Posted: Fri Dec 31, 2010 8:58 am |
Where can I get stainless steal exhausts for a 206, prefrably twins?
Posted: Fri Dec 31, 2010 8:59 am |
Before you go anywhere near powerflow I have literally spent all morning sorting mine out just uploading the pics to photobucket and you will see what I mean, and it went to a specialist powerflow garage to be done! DONT DO IT lol
Posted: Fri Dec 31, 2010 9:05 am |
That's just down to the people that work at the branch you went to. Myna been on the car for 4 years now never had a single problem with it and the workmanship is second to non. When I take it back every year for it's warranty check they even polish the back box to make it shiny again.
Posted: Fri Dec 31, 2010 9:37 am |
Powerflow and other custom outfits do not use mandrel bends. So you new system could well be more restrictive that the original system.
Posted: Fri Dec 31, 2010 9:43 am |
| JDave wrote: |
| Where can I get stainless steal exhausts for a 206, prefrably twins? |
Posted: Fri Dec 31, 2010 9:45 am |
