Latest: Beduff1977
Overall: 17134
Online Now [648]:
Visitors: 647
Today: 8121
Total: 108151073
Forums › The Car › 206 Talk › PowerFlow Exhausts
PowerFlow Exhausts
Go to page Previous  1, 2
Spanerman
PostPosted: Fri Dec 31, 2010 8:48 am Up
Edward wrote:
Powerflow and other custom outfits do not use mandrel bends. So you new system could well be more restrictive that the original system.
In a recent Redline issue they tested 3'' systems, a ''crinkle'' bent pipe and a mandrill bent pipe and the crinkle was only slightly down on power as most of the gas flows on the outside of the curve Smile
They had some silly gains on the car though, it was an impreza and they had 30bhp with the off the shelf one Smile
Sam.
Hello
JamieM
PostPosted: Fri Dec 31, 2010 8:59 am Up
If it's for performance gains powerflow are generally pap from numerous years on many forums, for just a factory replacement i'm sure they are ok though, i'd imagine they would be the best bet if you don't want a loud replacement, which is probably why they aren't good for gains (restrictive).
Aegean Blue 206 GTi180
PostPosted: Fri Dec 31, 2010 11:21 am Up
its just the backbox he wants so mandrel bends dont need to be taken into consideration here? (as apposed to a full system obviously)
PostPosted: Fri Dec 31, 2010 11:22 am Up
Mine seems fine
Mr_Cellexe
PostPosted: Fri Dec 31, 2010 3:31 pm Up
never had problem with mine from fitment to removal 50k later Smile
tbf there have been good/bad comments about most of the 'budget' aftermarket exhaust systems
PostPosted: Fri Dec 31, 2010 10:28 pm Up
No problems at all with mine!
no_offences
PostPosted: Fri Dec 31, 2010 11:02 pm Up
customs are s**t mines powerflow at the min and it could be so much smoother piping, my sportex on my old gti was cheaper and much better less piping better bends etc
Signature removed due to size
no_offences
PostPosted: Fri Dec 31, 2010 11:03 pm Up
never read the just a backbox bit, tbh it wont matter too much what you get
Page 2 of 2
