Online Now [206]:
Visitors: 205
Today: 85895
Total: 142899276
Forums › The Car › 206 Problems › oil leak
oil leak
Hpug
PostPosted: Fri Dec 31, 2010 2:09 pm Up
Hi again.
I have an oil leak on my 206hdi. Does anyone have any advice how best i can discover the source. Ive had a quick look but nothing is immediately clear. The leak isnt getting any worse but it is quite bad already. Could it be a turbo pipe as i have been losing power slightly recently
thanks
elcamino
PostPosted: Fri Dec 31, 2010 2:31 pm Up
You should first determine that is it gear box or engine oil.you can wash the area and find the source.
el camino. "Whether you think you can or you think you can't, you're right" Henry Ford.
Hpug
PostPosted: Fri Dec 31, 2010 2:38 pm Up
Ive done that it is def engine oil, been checking it on the dipstick too
PostPosted: Fri Dec 31, 2010 3:04 pm Up
if the leak is from the oil feed pipe to the turbo you better get it fixed soon. oil starvation is one of the main reason for turbo fail.
