Latest: tebas93089
Overall: 17179
Online Now [329]:
Visitors: 328
Today: 25879
Total: 138545505
Forums › The Car › 206 Problems › Limited power
Limited power
Aar_Im_A_Pirate
PostPosted: Sat Jan 01, 2011 5:23 pm Up
I'm still having power problems with the 2.0 Dturbo. The power drops at 3K and smokes alot from the exhaust with a quiet whine noise from the turbo.
The car works perfect when the weather is cold (plenty of poke). So far the air flow meter and temperature sensor have been changed.
Getting it hooked up for error codes in the next week or two. Sad
Anyone has similar problems??
Team: Derv
PostPosted: Sat Jan 01, 2011 5:26 pm Up
When was the cambelt last changed?
Get that checked.
Aar_Im_A_Pirate
PostPosted: Sat Jan 01, 2011 5:28 pm Up
Couldn't tell tbh, had a full service about 2000 miles ago. Want it sorted because over taking can be a bit scary when the car decides to play up
Team: Derv
Aar_Im_A_Pirate
PostPosted: Sun Jan 02, 2011 12:12 pm Up
*Bump* Any more ideas?
Team: Derv
mjsroofing
PostPosted: Sun Jan 02, 2011 1:00 pm Up
turbo???
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
mjsroofing
PostPosted: Sun Jan 02, 2011 1:05 pm Up
take the air intake pipe off and feel the centre part of the turbo fan see if there is movement
Mark
Aar_Im_A_Pirate
PostPosted: Sun Jan 02, 2011 1:54 pm Up
Naa its not the turbo, its has plenty of poke still, just depends on temperature outside or maybe amount of fuel =/ very hormonal
Team: Derv
mjsroofing
PostPosted: Sun Jan 02, 2011 2:04 pm Up
amount of fuel, ????
could the thingy in the fuel tank be broken, the bit that stops the fuel wosh around, or fuel filter???
Mark
Aar_Im_A_Pirate
PostPosted: Sun Jan 02, 2011 2:18 pm Up
all filters were changed 2000 mile ago. We thought it was the airflow meter and temperature sensor thing but nope, its like dominos..one code pops up, fix it, another appears. Blaaaaaaa (noise of rage)
Team: Derv
mjsroofing
PostPosted: Sun Jan 02, 2011 2:25 pm Up
but what would cause the turbo to whine?????
i'd say there is a propblem with the turbo some were.
does it boost to 3k, does it turbo at all. i think it is normaly about 1.8k the turbo gives boost isnt it.
Mark
Aar_Im_A_Pirate
PostPosted: Sun Jan 02, 2011 2:34 pm Up
turbo kicks in a 1.8 yeah and goes to 3k or so then nothing. But on a cold day the car revs up to 4, drives perfectly plenty of power.
At first we thought it could be faulty tuning box, so it came off and there's been no change.
Team: Derv
PostPosted: Sun Jan 02, 2011 2:35 pm Up
Does it have oil in it?
mjsroofing
PostPosted: Sun Jan 02, 2011 2:39 pm Up
have you checked the turbo just to rule it out, i have known them to cause this problem, if the bearing is lose, it will spin fast enough to turbo you up to 3k and then because of the bad bearing it will start to jam up or stick so you run out of turbo so too speak, I know i'm banging on about the turbo all the time but well worth a FREE check to rule it out before you spend any money, one thing a hate is spending money out before i've checked every thing i can myself.
Mark
Aar_Im_A_Pirate
PostPosted: Sun Jan 02, 2011 3:17 pm Up
Righto, cheers for the suggestions =D
Free stuff always sounds good ^^
More money for future mods.
Will keep ye's updated whenever I get this thing sorted
Team: Derv
Aar_Im_A_Pirate
PostPosted: Sun Jan 02, 2011 3:23 pm Up
@tom it does have oil in it
I may be a car noob but I do know where to dip my stick =D
Team: Derv
