Latest: tbafonso
Overall: 17130
Online Now [49]:
Visitors: 48
Today: 2741
Total: 103825100
Forums › The Car › 206 Problems › auxiliary belt removal
dj71
PostPosted: Sun Jan 02, 2011 1:58 pm Up
does anyone know how to release and remove the auxiliary belt on a 53 plate 1.4 petrol, for sum reason its different to mine in the haynes maual
dj71
Jammo
PostPosted: Sun Jan 02, 2011 2:12 pm Up
you probably got the wrong haynes manual as there's one for different years
Geoff
PostPosted: Sun Jan 02, 2011 2:14 pm Up
Are you looking at the correct engine page... A 53 plate car could be either an 8v or 16v engine!
PostPosted: Sun Jan 02, 2011 2:18 pm Up
Do you have AC or none?
dj71
PostPosted: Sun Jan 02, 2011 2:23 pm Up
its 1.4 sohc, no air con
dj71
PostPosted: Sun Jan 02, 2011 2:33 pm Up
Should look like this then
dj71
PostPosted: Sun Jan 02, 2011 2:42 pm Up
thats the 1 lee, cheers
dj71
dj71
PostPosted: Sun Jan 02, 2011 5:43 pm Up
also found this which helps a lot.
206 auxiliary/timing belt removal
dj71
