Latest: slaapkonijn
Overall: 17169
Online Now [172]:
Visitors: 171
Today: 13943
Total: 128679655
Forums › The Car › 206 Problems › brakes sticking
brakes sticking
scotty79
PostPosted: Sun Jan 02, 2011 3:27 pm Up
recently if i've left the car parked for a day or two, when first pulling away it seems as if the brakes have stuck to the discs and can take a bit of force to pull away, at first i just put it down to the cold weather but it's still doing it now the temp has went up, the front pads are needing changed which i will get done this week but was just wondering if it could be a more serious and pricey problem, also when i got the mot done i was told that the brake pipes are needing done but he said on a scale of 1-10, 10 being worst they were a 2 so it wasn't bad at all,
thanks in advance
mjsroofing
PostPosted: Sun Jan 02, 2011 3:30 pm Up
which brake pipes metal or flexy, the pads sticking to discs should be ok with new pads, or was it the rear shoes(handbrake) sticking
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
scotty79
PostPosted: Sun Jan 02, 2011 3:35 pm Up
sorry should have said, sounds mainly from the front drivers side but can't say for certain and really not sure about the brake pipes
mjsroofing
PostPosted: Sun Jan 02, 2011 3:43 pm Up
change pads and clean calipers, wire brush metal pipes and paint with shuts, flexy pipes must be changed for new and brakes will need bleeding, if you can bleed brakes you shoul be ok
Mark
scotty79
PostPosted: Sun Jan 02, 2011 4:07 pm Up
thanks, hopefully tha'll be all it is, could you tell me roughly how much it should cost me including new flexy pipes
PostPosted: Sun Jan 02, 2011 4:15 pm Up
Flexi pipes are around £8 / £9 each new from a Pug dealer.
scotty79
PostPosted: Sun Jan 02, 2011 4:21 pm Up
cheers, it's my dads mate who's garage i go to so i get the labour a bit cheaper was just wonderin how much i should expect to pay out
Alan
PostPosted: Sun Jan 02, 2011 6:52 pm Up
I have new calipers and flexy pipes if you need them mate. PM me if you want them.
cheers
Alan
scotty79
PostPosted: Sun Jan 02, 2011 6:59 pm Up
cheers mate, i'll let you know once I've been to the garage, how much would you be wantin for them?
