Online Now [294]:
Visitors: 293
Today: 104209
Total: 143302317
Forums › The Car › 206 Problems › Moisture inside the rear tail lights
Finnspeed
PostPosted: Sun Jan 02, 2011 7:40 pm Up
Another question from Finland. What is the best way to dry out the inside of the tail lights. There has been a build up of water droplets inside the light casing? We have had record low temperatures here (-22 degrees) and I think the seals have ruptured?
allanelstobonline
PostPosted: Sun Jan 02, 2011 8:18 pm Up
Phase 1 lights collect water, just take off the backings and empty them
eddrj
PostPosted: Mon Jan 03, 2011 4:41 am Up
mine do this too and i got phase 2
Old car 2000/ 206 2.0 hdi.
paulrushton
PostPosted: Mon Jan 03, 2011 5:03 am Up
Couple of sachets of silica gel in the bottom maybe once water poured out.
Peugeot 206 GTI HDI Black
elcamino
PostPosted: Mon Jan 03, 2011 5:53 am Up
After market lights are not fully sealed.had this problem.put light assy in very hot water and split it.after cleaning i used silicon and its fine.but be careful not to break light edge while removing it Smile
el camino. "Whether you think you can or you think you can't, you're right" Henry Ford.
