Latest: Beduff1977
Overall: 17134
Online Now [2243]:
Visitors: 2242
Today: 77769
Total: 109932549
Forums › The Car › 206 Problems › Help! Peugeot 206 Morette Headlights
gareth7o9
PostPosted: Mon Jan 03, 2011 6:20 am Up
Hi,
I've had my 206 since 2006 and have only had to change my headlight bulbs once or twice.
The other day one of my sidelights went and we've been trying to figure out how the hell you get to it. The headlights have a cap over but we can't seem to get to the sidelights.
My dad even started to remove the whole light but got stuck.
Does anyone know how to get to the sidelight bulb? I follwed what appears to be the wire but it does not pull out or unplug.
Failing this I will have to take it to my garage 2moro and see if they can have a go lol
What?
dan_206
PostPosted: Mon Jan 03, 2011 6:32 am Up
Side light bulb twists and then pulls out. Separate part that isn't under the cap.
4th 206 but finally a 180
Twist the sidelight bulb holder & it will pull out the headlight.
I take it there the original factory fitted standard headlights?
mattievrs
PostPosted: Mon Jan 03, 2011 6:36 am Up
If morettes can be called that! Rolling Eyes
NO LONGER ACTIVE ON THE FORUM
PostPosted: Mon Jan 03, 2011 6:37 am Up
The OP changed the title thread while I was posting my reply Wink
PostPosted: Mon Jan 03, 2011 6:42 am Up
you can see the sidelight wire here. Its the one on the top left with wire hanging out with the black connector bit. Its the same on the other side. It twists out like Dan said.
gareth7o9
PostPosted: Mon Jan 03, 2011 6:51 am Up
DJ- Thanks for the picture. That's what we were pulling on. I'll have a go and twist and pull now I know it's the right one.
What?
