Online Now [176]:
Visitors: 176
Today: 19067
Total: 143217273
Forums › The Car › 206 Problems › Dashboard Clock Issues
kal_1983uk
PostPosted: Tue Jan 04, 2011 9:31 am Up
Hi,
I have a 206, 52 (2002). I have just fitted a new JVC headunit but now experiencing issues with the clock on the dashboard.
When the ignition is off the clocks time is correct and ticks over fine. Soon as I put the ignition and stereo on the clock stops working.
Has anyone else experienced this problem? Any help would be great.
kal_1983uk
00budham00
PostPosted: Tue Jan 04, 2011 9:47 am Up
always have problems with my 209 gti's clock
pain.. take it out and put a tv there !! 7inch looks the best but have to relocate hazards
kal_1983uk
PostPosted: Tue Jan 04, 2011 9:55 am Up
Is there no way I can get the original clock to work correctly?
It kind of does, just not when the stereo is on it stops ticking over untill you switch the engine off where it then updates to the correct time.
kal_1983uk
PostPosted: Tue Jan 04, 2011 10:46 am Up
Just re-wire it.
kal_1983uk
PostPosted: Tue Jan 04, 2011 10:52 am Up
Which wires would I need to re-wire?
kal_1983uk
PostPosted: Tue Jan 04, 2011 11:04 am Up
Pin's 7 & 9 would go to a new positive feed.
Pin 8 should be fine as thats just a chassis earth
Pin 4 & 17 are the Van wires that go to the instrument panel, I think you'd need to d/c these.
Infact, just try removing pins 4 & 17, and see what happens.
