Latest: Kifi69
Overall: 17183
Online Now [566]:
Visitors: 565
Today: 28962
Total: 143868987
Forums › The Car › 206 Problems › handbrake light constantly on
benb
PostPosted: Wed Jan 05, 2011 10:09 am Up
my handbrake light is constantly on it works fine just the light stays on any help?
thnks ben
1.1lx 2000 plate
giveitsomebar
PostPosted: Wed Jan 05, 2011 10:15 am Up
your brake fluid is proberly dangeriously low
eddrj
PostPosted: Wed Jan 05, 2011 10:31 am Up
yeah that happens when brake fluid needs topping up best check it asap
Old car 2000/ 206 2.0 hdi.
Jack4273
PostPosted: Wed Jan 05, 2011 11:38 am Up
either that or check the cable that connects the the handbrake switch under your handbrake
Clarion VZ409E 7 inch DVD motorised screen
Sony XMZ-R604 440 watts Channel Amplifier
Vibe Slick 12" 1200 watt Subwoofer
Pioneer TS-A6903i 6 x 9 3-way 350 watts
Raceland 4-2-1 Stainless Steel Manifold
Remapped Ecu
Wolfrace Street Hustle 17"
Very Happy
Click For Da WIP! 206info.co.uk/Garage/m...d=336.html
benb
PostPosted: Wed Jan 05, 2011 12:09 pm Up
cheers everyone i must of knocked it the otherday it was the swtich under the handbrake. i ran out there with some brake fluid n it was full so i double checked in side n it was the switch thanks for the help every one
1.1lx 2000 plate
sillyhilly
PostPosted: Wed Jan 05, 2011 12:34 pm Up
I'd check the brake pads as well. the light comes on when they're low.
Hi Mikey Smile
elcamino
PostPosted: Wed Jan 05, 2011 3:32 pm Up
If the hand brake light is on with no STOP light flashing on dash and no beep its the switch stuck under hand brake.
el camino. "Whether you think you can or you think you can't, you're right" Henry Ford.
benb
PostPosted: Wed Jan 05, 2011 4:02 pm Up
just done my brakes like 3 weeks ago was the switch under the handbrake Smile thanks for help
1.1lx 2000 plate
PostPosted: Thu Jan 06, 2011 4:43 am Up
Correct.
Unless the STOP warning light is on at the same time as the (!) its always the handbrake switch.
If you get STOP & (!) then check the brake fluid Wink
jakehorton
PostPosted: Mon Jan 17, 2011 7:36 am Up
Ive got this problem with the STOP light flashing, (beeps sometimes to) and the (!) light at the same time. I have checked brake fluid and thats fine. It is fairly intermittent in terms of when it flashes, could go a long time with nothing or a few minutes. Will always happen though. How do you check the handbrake switch? or what else could it be? So annoying! And every genius who gets in your car likes to point out to you that there's a light flashing on your display as if you havent noticed!!!
Any help mucha appreciated!
PostPosted: Mon Jan 17, 2011 7:43 am Up
Its a brake fluid low issue OR the switch in the brake fluid bottle cap / connection Wink
Hereford
PostPosted: Fri Jan 27, 2012 5:00 am Up
Trade Rating: +20
I've had this happen to me, I thought it was the hand brake at first.
The hand brake light flickered on and off and beeped without the stop light flashing.
Day after it happened again, but the text "break fluid levels low" came up on the dash with the flashing red STOP and hand brake light.
I've had NO problems at all apart from 3 weeks ago where it happened the same way.
I topped up the brake fluid, must admit it took about 30ml/40ml of fluid.
It's now happening again??
You think it could be a faulty fluid pot or connection?
Cheers chaps
Peugeot 206 HDI SW SXI
"What goes around, Comes around"
"Fail to prepare, Prepare to Fail"
WIP Black Death - 206info.co.uk/Forums/v...39788.html
WIP NEW -
www.206info.co.uk/Foru...43987.html
