Posted: Wed Jan 05, 2011 2:18 pm |
Does basic AC have a ECU like CC+DAC?
Ta
Posted: Wed Jan 05, 2011 2:42 pm |
No I don't think so.
The switch just turns the compressor on. Its not controlled via temperature or rate of flow.
Posted: Wed Jan 05, 2011 2:47 pm |
Didn't think it had one, was just checking because when I plugged PP in I get "ECU undetectable" and the air con doesn't work. The fan doesn't even come on when I switch it on.
Looks like I'm troubleshooting with the multimeter then.
Posted: Wed Jan 05, 2011 2:53 pm |
Lee wrote: |
Does basic AC have a ECU like CC+DAC? |
Yeh its connect to DBA via the CCA reffered by the EAP
| Team Impossible Possible
its monitored by the ecm, and bcm generally. whats the problem with yours? ( im aircon f-gas certified il have you know )
| 2.0 hdi 90
challenger alloys
-40mm spax shocks and springs
gti 180 calipers, groved discs
braided brake lines
turbo back pro-speed exhaust
de-egr'd | |
Posted: Wed Jan 05, 2011 3:05 pm |
Just doesn't work at all
The light comes on when pressed, but doesn't get any hotter/colder. Nor does the fan like it should when its switched on. The fan does work as I tested that with PP, and it spins fine. The idle doesn't increase either when the car is stationary and the AC is activated.
Posted: Wed Jan 05, 2011 4:18 pm |
Does the compressor clutch engage? You can hear it clunk as it switches on.... though I guess not as the idle would be affected.
The compressor won't kick in due to inadequate refrigerant, check for leaks around the condenser/pipe work. It probably isn't the compressor thats at fault because in our climate its not overly worked.
Posted: Wed Jan 05, 2011 4:46 pm |
Nah it does nothing except the little green light comes on.
I'll have a gander, need to service it and change the drop links anyway
Posted: Thu Jan 06, 2011 3:37 am |
Lee wrote: |
I'll have a gander, need to service it and change the drop links anyway |
It could be low / out of gas
The pressure safety switch will prevent the ac compressor running to protect the system & your wallet.
Posted: Fri Feb 04, 2011 10:06 am |
Think I've found the problem, scanned it today and got this.
P1110 - Air Conditioning cut off circuit - Short Circuit to Earth or Circuit Open
