Latest: tbafonso
Overall: 17130
Online Now [301]:
Visitors: 300
Today: 15081
Total: 104427286
Forums › The Car › 206 Problems › Noise from alternator belt
Taff!
PostPosted: Thu Jan 06, 2011 10:31 am Up
A while back I mentioned I had problems with my alternator belt. Well I had a look at it and now so has a gargae and we have both come back with the same diagnostic and that it's either the alternator or the power steering pump. Tensioners are fine but how can I distinguish which one is the problem? Both freewheels spin freely and don't give any sign of any issues. Don't really know where to go from here really.
206 1.6 Quiksilver
PostPosted: Thu Jan 06, 2011 10:56 am Up
Spray WD40, or the like, on the alternator. If it goes quite, that could be your culprit.
Taff!
PostPosted: Thu Jan 06, 2011 11:01 am Up
I've tried to spray both of the freewheels as best I can but that's not made any difference to the sound. Don't really want to douse the alternator completely in WD40 as I don't want to saturate the brushes
206 1.6 Quiksilver
PostPosted: Thu Jan 06, 2011 11:17 am Up
i got a short belt from an old car (or they used to sell short universal, strechy ones in my local motor factors) so i could remove the power steering pump or alternator off the belt to work out what one it was on an old car i had once.
Taff!
PostPosted: Thu Jan 06, 2011 11:27 am Up
Didn't think of that. Will get myself a shorter belt and try it. Thanks
206 1.6 Quiksilver
PostPosted: Thu Jan 06, 2011 12:35 pm Up
usually the sound on the alt. belt is caused by the 2 pulleys that make the belt cycle,they get worn out because of dirt and water.
if not these 2,then maybe your alten. itself make the noise.
