Latest: SA01
Overall: 17138
Online Now [308]:
Visitors: 307
Today: 20475
Total: 111266999
Forums › The Car › 206 Problems › One Key ... Doh!
One Key ... Doh!
xpda
PostPosted: Thu Jan 06, 2011 2:55 am Up
Purchased 206 (X reg) for the wife.
It only came with one key (not the remote key) ....but no key codes to get another one cut.
I did not realise they were such a nightmare when this problem occurs.
Can anyone help out with getting the transponder code and maybe the mechanical key cut code I need - and where to get such a key cut and coded?
Checked the Stealer route and it sounds a right lot of hoops to jump through & £160+
Mrs_Howey
PostPosted: Thu Jan 06, 2011 3:25 am Up
Pm Lee, he should be able to get all this information for you from your VIN number Smile
Moonstone blue 206 1.4look
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre Very Happy
PostPosted: Thu Jan 06, 2011 4:50 am Up
Standard non remote key is around £20 supplied & cut BUT it also needs to be coded to the car to start it.
If you haven't got the 4 digit transponder code & also the key cut code then Peugeot will provide them for a small charge.
You need the V5C logbook & also photo id before Peugeot will issue:
Transponder codes.
Key codes.
A key.
PM Lee with the 17 digit VIN number for the car & ask him nicely as sometimes he can get hold of the codes for you Wink
xpda
PostPosted: Thu Jan 06, 2011 5:45 am Up
Many thanks Mrs_Howey & MrBSI
Comments appreciated greatly - do not want to get totally stuck by loosing/breaking the one key.
I shall PM Lee and see what he can do - I noticed in some other posts that he had offered to find the codes for others but I felt a bit cheeky PMing him directly.
Anyway shall do that now.
Again many thanks for the responses Mr. Green
xpda
PostPosted: Thu Jan 06, 2011 8:11 am Up
I have PM'd Lee, but...
The PM remains in my OutBox - it has not moved to my Sent Box
I am not sure if this is correct?
Does it only move to my SentBox after Lee is online to receive it or have I done something wrong?
WTF?
T_bandery
PostPosted: Thu Jan 06, 2011 8:13 am Up
When Lee has read the PM, it will move to your sent box Wink
xpda
PostPosted: Thu Jan 06, 2011 8:15 am Up
Thanks for that info... still getting used to the forum methods Embarassed
PostPosted: Thu Jan 06, 2011 11:13 am Up
Read and replied Laughing
xpda
PostPosted: Thu Jan 06, 2011 1:01 pm Up
Lee - you are truely a star man Thumb Up
Many thanks for your help.
Now then with this information do I simply go to Peugoet or is there a cheaper way?
What should I expect to pay?
PostPosted: Thu Jan 06, 2011 1:07 pm Up
Key - cgi.ebay.co.uk/Peugeot...1230wt_905
Key blade - cgi.ebay.co.uk/PEUGEOT...5d2ce16640
Take it to a autolock smith and they should cut the key blade and recode the transponder chip.
EDIT: Let me just double check thats possible.
xpda
PostPosted: Thu Jan 06, 2011 1:45 pm Up
Ah - I see - you buy a 2nd hand key, get a new blade and get a lock smith to recode the key and cut the blade
Its starting to make sense now
PostPosted: Thu Jan 06, 2011 3:11 pm Up
You can't get the transponder chip recoded, unfortunately
xpda
PostPosted: Thu Jan 06, 2011 3:14 pm Up
Many thanks for checking
At least I have the codes.
So i guess it has to be from Peugeot?
WTF?
PostPosted: Thu Jan 06, 2011 3:21 pm Up
Try places like this - angellocksmiths.co.uk/...ponder.php
xpda
PostPosted: Thu Jan 06, 2011 3:29 pm Up
Wicked - thanks again for your time Mr. Green
They seem to have a write up about the pre and post 2001 models and variations in keys so looks hopeful
Razz
They also have details on pricing
www.tonyandrews.net/ca...hp#peugeot
