Latest: S2cgm
Overall: 17178
Online Now [92]:
Visitors: 91
Today: 100495
Total: 137250074
Forums › The Car › 206 Problems › Sidelights arent working
Luken54632
PostPosted: Thu Jan 06, 2011 3:53 pm Up
right my front sidelights arent working, my back lights arent working, 2 of my brake lights arent working, and i hav no clue as to why. i have changed all the bulbs and changed the fuses and still not working and i dont no what else to try
Dabamash
PostPosted: Thu Jan 06, 2011 3:57 pm Up
Staff - Daba
These things normally fall down to a dodgy earth. Where's lee?
PostPosted: Thu Jan 06, 2011 3:59 pm Up
Does the dipped and main beam work?
Check fuses #11, #12, #18, #34 # in the drivers fuse box. Fuses #5 and #32 in the engine fusebox
You run a +12 feed to each of them to see if they work manually?
XSIcheeseman
PostPosted: Thu Jan 06, 2011 5:50 pm Up
its a bad earth somewhere behind the dashboard i had the same problem
New and Improved!
New Project
www.206info.co.uk/Foru...51199.html
Luken54632
PostPosted: Thu Jan 06, 2011 5:52 pm Up
sweet cheers i will try these in a min
Luken54632
PostPosted: Thu Jan 06, 2011 5:55 pm Up
is there a specific place where the earth is or is it different for everycar??
Luken54632
PostPosted: Thu Jan 06, 2011 6:14 pm Up
and yer both main beam and dipped beam work
MC20
Luken54632
PostPosted: Fri Jan 07, 2011 4:39 pm Up
Cheers found out thqt some wires in boot were touching and short circuited all my lights lol cheers fr all the help
