Latest: tbafonso
Overall: 17130
Online Now [303]:
Visitors: 302
Today: 19522
Total: 104209206
Forums › Tuning, Modification & Legal › Project Cars › 206 GTI 180 Rally car project
Go to page Previous  1, 2, 3 ... 6, 7, 8 ... 11, 12, 13  Next
st3v3n
PostPosted: Sun Jan 02, 2011 12:30 pm Up
That film is a t**t to fit. I tried mine last week but give up and pulled it off. just waiting on a reply from plastics4performance for a price for the rear screen. I was even thinking of trying to heat up some polycarb between 2 glass screens and making my own, but at £80 a sheet it could all go wrong.
ICE goes in drinks. NOT in cars.
macj
PostPosted: Sun Jan 02, 2011 1:11 pm Up
I got my signwriter who is a sponsor to fit my film.... he said the same thing..... its got no flex and it looks bad.... going down the poly route now. Just waiting on prices
imjeeves
PostPosted: Fri Jan 07, 2011 4:15 pm Up
Look at what the postman brought me this week Very Happy Twisted Evil
180 Front brakes as my 406 Brembos wont fit under the 15 inch on gravel without problems
Jenvey throttle bodies and manifold etc and a carbon fiber strut brace to top it all off.
PostPosted: Fri Jan 07, 2011 4:21 pm Up
Have fun with the mapping.....
imjeeves
PostPosted: Fri Jan 07, 2011 4:24 pm Up
My base map is already sorted. I know another guy that rallies a 180 and he has kindly given me his map to start with. Will need to take it to the rolling road to get it the way I want though.
Emerald ECU's are where its at!! Smile
PostPosted: Fri Jan 07, 2011 4:30 pm Up
That's the first time I've seen the cam sensor in the 180, it's normally hidden. You running a servo? I take it the levers on the bodies need removing? Is your TPS going on the TB closest to the gearbox?
PostPosted: Fri Jan 07, 2011 4:33 pm Up
I will reserve my judgement as a certain longman took rather long to have a 180 on TB's set up right
imjeeves
PostPosted: Tue Jan 25, 2011 1:32 pm Up
Got some more painting done in the warmer weather! Also got the radiator fitting with the TB which were sitting far too close. Wiring is still going on. Made myself a handbrake mount which im actually pretty happy with. Starting to look more like an actual car now! Very Happy
macj
PostPosted: Tue Jan 25, 2011 2:16 pm Up
looking good mate..... its the best part of the build from now on
briant
PostPosted: Tue Jan 25, 2011 6:06 pm Up
What rad did you use? can i be real cheeky and ask you to take few close up pics of rad and throttle bodies area please
Also what length trumpets are you running on tb's
ps. your build is coming along very nicely Very Happy
206 Rallycar
Schumi
PostPosted: Wed Jan 26, 2011 10:08 am Up
Looking amazing. Do you have closer pictures of side skirt
2005 206 RC RED
imjeeves
PostPosted: Wed Jan 26, 2011 10:20 am Up
Im home on Friday for four days so I will get some more pictures then. Hoping to get all the wiring done and the fuel lines in. New wheels should be here on Friday so im looking forward to that.
Side skirts are made of kaylan. It has the same material all along the underside of the car as well. Seems good stuff but not cheap
imjeeves
PostPosted: Thu Feb 03, 2011 7:10 am Up
More updates.
8 new Revolution wheels arrived. New model GR6 wheels which are very nice.
Got another 6 to come possibly in a month or two so thanks to Revolution for those Smile
Got my fuel pressure regulator fitted and new radiator hose as it is now lower. More wiring done. Digital dash fitted in place but I forgot to take pictures. Im back tomorrow night so no doubt I will get some more pictures.
imjeeves
PostPosted: Thu Feb 03, 2011 7:15 am Up
Engine bay
st3v3n
PostPosted: Mon Feb 07, 2011 6:35 am Up
Looking good mate. Keep up the good work!
Page 7 of 13
