Latest: jackrox1992
Overall: 17186
Online Now [379]:
Visitors: 378
Today: 55541
Total: 148435185
Forums › The Car › 206 Problems › OSF knocking over any bumps
JJ0063
PostPosted: Thu Jan 06, 2011 4:41 pm Up
Hi all,
My front drivers side has started knocking alot, over the tiniest of defect in the road it sounds like metal knocking on metal. there is no vibrating or pulling to a side
is this just a bush or something? are there any common issues with 206 suspension?
the car has been lowered in the past so wouldnt suprise me if a bush has worn!
PostPosted: Thu Jan 06, 2011 4:42 pm Up
Does the sound come from high up? Could be the top mount bearing. Or a drop link.
JJ0063
PostPosted: Thu Jan 06, 2011 4:45 pm Up
Cant really tell to be honest, I checked to see if the drop link had snapped but it seems tight, havent had the car up in the air yet though.
pug_206
PostPosted: Thu Jan 06, 2011 7:23 pm Up
it be ya ANTI ROLL BAR had the same thing on gf car cost me 12 pound an a 15mins easy job
cgi.ebay.co.uk/NEW-PEU...35a1247065
bmw e46
imjeeves
PostPosted: Thu Jan 06, 2011 8:13 pm Up
They are drop links which connect to the anti roll bar! Yes as stated before it will be these that are knackered. Only a 10 minute job! I would do both sides as if one is gone chances are the other will be close to going as well
doughboy5
PostPosted: Fri Jan 07, 2011 5:13 am Up
i have had the same thing over the last couple of days happen but dosnt sound like meta on metal just sounds like a knocking sort of sound hard to explain. would this be the same
206 GTi
imjeeves
PostPosted: Fri Jan 07, 2011 5:30 am Up
Yes it is the first part of the suspension to go. It is because of all the holes in the road just now!
doughboy5
PostPosted: Fri Jan 07, 2011 5:34 am Up
cool are they easy to fit i know someone said it is a 10 minute job but i have no idea where these are hehind the wheel and how easy they are to do
206 GTi
maximus.darby
PostPosted: Sat Jan 08, 2011 7:55 pm Up
yep, anti roll bar, mine did the same thing, fixed within 15 minutes, noise disappeared Smile
Max Darby
Peugeot 206 Quiksilver, 1.4, 51 Reg, 34,000 Miles
JJ0063
PostPosted: Wed Jan 19, 2011 9:43 am Up
Fixed this today.. turned out to be something completely different! ECU had somehow worked it's way loose.. tightened the bolt up... no more knocking Very Happy
