Online Now [239]:
Visitors: 238
Today: 33266
Total: 143101730
Forums › The Car › 206 Problems › Changing speedo sensor
PistolPete
PostPosted: Mon Jan 10, 2011 5:49 am Up
Hi All,
I've had my speedo seeming die. Oddly it started playing up and the same time as a slight drop in power on the motorway at 60-ish, and it would feel like heavy wind into the front of the car. When the speedo started working again the power would perk up.
The next day the speedo stopped altogether and the ODO is now no longer working so I suspected the speedo sensor (I'd had problems before with a sticking needle, but the ODO was still working then and a speedo sendor is cheaper than a cluster!!)
I got a replacement and went to fit it and removed what I thought was the speedo sender - top of the gearbox pretty much straight under the MAF sensor housing.
I pulled it out - looked like I was expecting, a threaded end with a small brass nipple coming out of the end which is slightly spring loaded - I assumed a hall effect type sensor picking up notches in the gearbox somehow. I get the replacement out of the box and it's not the same.
I googled for an image of the speedo sensor and found pics of the same thing I'd been sent (this is not my old one and the new one is the same minus the cog on the bottom)
My questions are these:
1) Is what I've been sent correct for a 2000 2.0 HDI 90?
2) If so, where is it located
3) Also, what did I take out??
If need be I'll take a pic of the location of what I took out and post it on the thread later.
Thanks for looking
Pete
2000 (W) 206 DTurbo 90.
PostPosted: Mon Jan 10, 2011 7:10 am Up
Have you removed the crank sensor? The speed sensor is right at the back of the gearbox on the final drive.
PistolPete
PostPosted: Mon Jan 10, 2011 7:19 am Up
I've googled the crank sensor and I can't find an image that matches what I had, but I guess it's possible as this was front the front / top of the gearbox and can be seen if you look down just to the right hand side of the MAF housing.
I'll have a look from under the car at the back of the gearbox.
Thanks for the reply - hopefully I'll be looking in the right place now!!
PostPosted: Mon Jan 10, 2011 7:57 am Up
You didn't take out the reverse light switch did you?
PostPosted: Mon Jan 10, 2011 10:38 am Up
It sounds like it to me Laughing
PistolPete
PostPosted: Tue Jan 11, 2011 12:52 pm Up
Hahaha. Googled the reverse light switch and BINGO!!
PostPosted: Tue Jan 11, 2011 2:21 pm Up
Dimebar!
macj
PostPosted: Tue Jan 11, 2011 2:28 pm Up
Any idea of the wiring on a speedo sensor..... Is there a power feed to it from ECU and would it have a pulsed signal output??
erick3.14
PostPosted: Tue Jan 11, 2011 6:50 pm Up
yes... that is true... it is connected to +12v and it generates pulses... the higher speed the higher is the frequency.
I was tweaking with speed sensor and found that slower speed is around 70ms for the hi-level pulse... and the faster you go, the smaller will be the pulse duration.
206 2.0 engine swapped
Project Loading: GTI 180 interior replica construction
Next Step : turbo charge the 2.0
My project blog : swapando.blogspot.com/ (sorry for not being in English)
