Online Now [646]:
Visitors: 645
Today: 38423
Total: 128139856
Forums › The Car › 206 Problems › 206 failed mot today :( emissions
charlie-52
PostPosted: Mon Jan 10, 2011 1:22 pm Up
okay so i took my car for an mot today and it failed on emisions
it failed on the "CO" and the reading on the lambda was 0.949 and min was 0.970 does any one know why this might be like this?
also failed on nearside frount ball joint has excessive play... do you have to buy a whole arm or can you just get the ball joint?
headlamp too low
any help will be appricated Smile
PostPosted: Mon Jan 10, 2011 1:23 pm Up
last time serviced/oil change?
PostPosted: Mon Jan 10, 2011 1:24 pm Up
Service it properly, put some premium fuel in and rag it down the country lanes Wink
Infact just ragging it down the lanes might be enough.
charlie-52
PostPosted: Mon Jan 10, 2011 1:27 pm Up
it has full service history emm was seviced in april last year so might be worth trying
PostPosted: Mon Jan 10, 2011 1:30 pm Up
Should be serviced every 10/12k, and ideally a oil and oil filter change every 5k.
When you do the next service, do everything.oil filter, air filter, oil, fuel filter, spark plugs, pollen filter, maybe even gearbox oil and coolant as well
charlie-52
PostPosted: Mon Jan 10, 2011 1:33 pm Up
okay looks like im taking a trip to my local car parts giving it a service tho wouldnt that bring my emisions down rather than higher as lookng at the sheet it failed becuase it was too low Sad
Andy180+
PostPosted: Mon Jan 10, 2011 1:56 pm Up
the lambda is the amount of air in the exhaust system, possible you may have a small leak somewhere on a joint. does the print off they gave you say what the oil temp was at time of test??? has to be minimum of 80c
charlie-52
PostPosted: Mon Jan 10, 2011 2:01 pm Up
yea says oil temp deg C:
min limit 60
max ------
actual value 63
pass/fail pass
Andy180+
PostPosted: Mon Jan 10, 2011 2:28 pm Up
ok so at least you know the cat would have been upto temp. would have failed on co aswell otherwise anyway. sounds as though it could be either down to a partially blocked air filter or maybe even the lambda sensor on the exhaust . how old and what engine ?? miles???
