Latest: Willy.Sea
Overall: 17168
Online Now [210]:
Visitors: 209
Today: 30839
Total: 128532990
Forums › The Car › 206 Problems › A bit of help
A bit of help
PostPosted: Tue Jan 11, 2011 7:28 am Up
Hi
Can someone tell me the difference betweent these to part numbers
6429S1
6429P0
They are for the drivers wiper arm which I need to replace.
T_bandery
PostPosted: Tue Jan 11, 2011 7:34 am Up
One says S1 at the end and the other says P0... i think
Razz
Without checking, if they are both listed on the same thing eg drivers right arm.
Then one is for a 22" blade and the other is a 26" blade.
You want the latest/biggest RPO/DAM number as that will be 22"
PostPosted: Tue Jan 11, 2011 7:37 am Up
So Iv got to go for 6429S1 then?
PostPosted: Tue Jan 11, 2011 7:38 am Up
Yeah.
Just checked and thats the part number you want [SINCE RPO No. 08470]
PostPosted: Tue Jan 11, 2011 7:39 am Up
You got a price Lee?
PostPosted: Tue Jan 11, 2011 7:41 am Up
Comes up at £62.02 including VAT
PostPosted: Tue Jan 11, 2011 7:43 am Up
Thanks Lee. fingers crossed that solves the problem
PostPosted: Tue Jan 11, 2011 7:44 am Up
What's the problem?
PostPosted: Tue Jan 11, 2011 7:48 am Up
I had it last year and it has come back.
Right in my eye line where the hook is on the blade, about 2 inchs up from the base of the screen in a curve it misses the screen. I have tried the trick of putting a cable tie on the spring to pull it tighter, worked for a bit but not now. It has become dangerous to drive in the rain as the screen is not clearing right where that is.
Been told the arm has gone.
PostPosted: Tue Jan 11, 2011 7:54 am Up
Yeah it probably is the arm thats gone then. Unless the wiper blades you are running are too big so they aren't going flush to the screen.
PostPosted: Tue Jan 11, 2011 7:56 am Up
Iv got the Bosch Aeros 21" and they have been fine, I have even swapped the blades over and it still happens
PostPosted: Tue Jan 11, 2011 7:57 am Up
Must be the arm then like you said.
PostPosted: Tue Jan 11, 2011 7:59 am Up
Cant see it being anything else to be honest
