Posted: Tue Jan 11, 2011 12:10 pm |
Why would he need to change the switch? I put phase 2 crystals on when i had frosted and just had a relay harness. switches were fine.
Oh, just the stalk? Ah right. That's easy enough. So just having a phase two stalk will make both lights stay on?
Posted: Tue Jan 11, 2011 12:11 pm |
No youll need to wire relays in. Or get the adapters with relays as some people sell
Posted: Tue Jan 11, 2011 12:12 pm |
We think you might be able just to fit the H7 connectors and a stalk from like GTi, and they'll work like normal.
Without the need for any other relays or adapter.
DJ- wrote: |
No youll need to wire relays in. Or get the adapters with relays as some people sell |
Its a non plexed car.
The relays are already there, its just getting them working in the correct order.
I know mine was preplexed too?
Posted: Tue Jan 11, 2011 12:13 pm |
I already have a relay harness for the angels, will this not work?
Posted: Tue Jan 11, 2011 12:14 pm |
DJ- wrote: |
I know mine was preplexed too? |
Did you try changing the headlamp stalk for one from a crystal equipped car?
I'm getting confused now.....haha
Posted: Tue Jan 11, 2011 12:15 pm |
MrBSI wrote: |
DJ- wrote: |
Did you try changing the headlamp stalk for one from a crystal equipped car? |
Nope are they different??? They both push/pull the same direction the same times dont they?
Posted: Tue Jan 11, 2011 12:19 pm |
DJ- wrote: |
MrBSI wrote: |
DJ- wrote: |
Nope are they different??? They both push/pull the same direction the same times dont they? |
Yes.
We reckon a crystal headlamp switch will operate the 2 relays in the correct way for the crystal lights.
Its a bit odd that Peugeot list 3 switches.
Single optic & NO front fogs ( not worried about this one in this thread )
Single optic with front fogs.
Double optic with front fogs.
Why list 2 different switches that look exactly the same on the outside
We reckon there wired differently inside.
Posted: Tue Jan 11, 2011 12:20 pm |
I see, are they cheap enough to buy new? I could always find one from a scrappy
Posted: Tue Jan 11, 2011 12:21 pm |
Ow iv just read the start of page 1 and realised where you're coming from
Indeed if they list them then maybe so. But wouldnt one switch be for multiplexed cars and as his is preplexed, would it plug in and/or even work?
Posted: Tue Jan 11, 2011 12:23 pm |
Would I not just have to get a pre-plexed phase 2 stalk then?
Posted: Tue Jan 11, 2011 12:24 pm |
Oh jeez im getting mixed up. Of course, pleplexed stalk from a gti I see!!!
