Online Now [608]:
Visitors: 607
Today: 98943
Total: 105825547
Forums › The Car › 206 Talk › gti backbox
gti backbox
sc206
PostPosted: Wed Jan 05, 2011 5:08 pm Up
help needed, will a gti backobx, fit a 1.1?
MrZiggerz
PostPosted: Wed Jan 05, 2011 6:16 pm Up
More than likely
lofty
PostPosted: Wed Jan 05, 2011 7:18 pm Up
It won't run well with it on if you get it on..
206 GTI
Nimrods
SP Grille
Cargo Net!
Leader Team: Tivoli GTI
Leader Team: Cargo Net
Snowboard & Bindings For Sale
meady
PostPosted: Thu Jan 06, 2011 1:33 am Up
Trade Rating: +45
It wont be a direct fit it will need a bit of a modification. Why wouldnt it.run very well?
TEAM - I HATE FACEBOOK Smile
PostPosted: Thu Jan 06, 2011 11:33 am Up
The bore is bigger connecting to the centre pipe so it won't fit properly and the fumes will be let out. Will need to be welded on and have extra material covering the gap.
meady
PostPosted: Fri Jan 07, 2011 4:27 am Up
Trade Rating: +45
So aslong as you get it properly fitted so tht the exhaust is sealed thwn it will alm be fine
lofty
PostPosted: Tue Jan 11, 2011 1:42 pm Up
Backpressure?
206 GTI
Nimrods
SP Grille
Cargo Net!
PostPosted: Tue Jan 11, 2011 1:57 pm Up
Pointless fitting one.
