Latest: cogeim7
Overall: 17185
Online Now [490]:
Visitors: 489
Today: 200183
Total: 147479569
Forums › The Car › 206 Talk › 206 gti 180 water pump housing
Forum Index › 206 Talk
danjames
PostPosted: Tue Jan 11, 2011 3:17 pm Up
i have a slight water leak on my 180 and it appears to be coming from where the water pump housing bolts the water pump i think Confused does anyone have any diagrams or pics for this or know how hard it is to remove the water pump housing? thanks
blue gti 180, anthrecite wheels, lowered 60mm, debadged bonnet, debadeged grill, morettes hid in headlights an fogs, full sp pack, WANTED CAT CAMS NOWWWW
PostPosted: Tue Jan 11, 2011 3:20 pm Up
When was the cam belt done? As you would normally replace the water pump at the same time.....thus killing 2 birds with one stone.
danjames
PostPosted: Tue Jan 11, 2011 3:31 pm Up
not long ago and no didnt change that, didnt even come to mind tbh, i havnt checked the water since iv owned the car and while the car was in the garge it froze up (no antifreeze) and now it has defrosted has started to leak so im guessing thers a seal or somthing broke.
kieron
as mikey said, if it wasnt changed when the belt was done the new belt would wear the old pump out faster
could be a costly mistake as the 180 is a pain in the ass to do and can cost alot of money as its labour intensive
Account suspended
PostPosted: Tue Jan 11, 2011 3:34 pm Up
I would think new belt and water pump again to be on the safe side
danjames
PostPosted: Tue Jan 11, 2011 3:38 pm Up
the thing is though ive been looking for a new water pump but from what i can see its just a pump and not the housing so that wouldnt acheive anything i dont think, is there a core plug up there somwhere?
PostPosted: Tue Jan 11, 2011 4:14 pm Up
No it wouldn't.
Is the pump itself leaking or where the pipe at the back of the engine enters the pump?
dturbopeck
PostPosted: Tue Jan 11, 2011 5:35 pm Up
Dealer do a modified water pump and housing it comes complete it's about £50, if I was doing that I would change timing belt again,
kieron
PostPosted: Tue Jan 11, 2011 5:39 pm Up
Edward wrote:
No it wouldn't.
i forgot you are a expert and you know loads of stuff
Account suspended
dturbopeck
PostPosted: Tue Jan 11, 2011 5:42 pm Up
gti180boy
PostPosted: Tue Jan 11, 2011 7:07 pm Up
Yes they do, do a upgrade one and its not £50 its round £70 from dealer.
If the cambelt was replaced only 5000 or so miles ago i would just remove the belt and replace water pump and refit the belt, but if the water has been leaking on to the cambelt or the car has done alot miles since the cambelt was changed then best to replace the cambelt again, and the other thing is that the tensioner some weaker every thing you remove and instill it i have find which ant good really.
Iv seen alot of water pumps leak now on gti 180s when i have been doing cambelt on these's and i will never change a cambelt with out doing the water pump aswell, they normaly leak from the seal behind the pully where the shaft sticks out.
If you need the water pump doing am sure i could sort this out for you Smile
Regards
Kyle
180 Doctor
PostPosted: Wed Jan 12, 2011 1:07 pm Up
kieron206gti wrote:
Edward wrote:
No it wouldn't.
Well how would a new belt wear the pump more? The belt only touches the pulley which never wears out. The bearings and seals wear out and the fact a new belt is fitted won't make a difference to the wear rate.
Schumi
PostPosted: Wed Jan 12, 2011 3:31 pm Up
Hi Kyle. What is that modification or upgrade. Can you give detail.
2005 206 RC RED
gti180boy
PostPosted: Thu Jan 13, 2011 2:05 pm Up
Well
Every single one i have remove all come made of plastic and says mrk 4 or 5 ( cant emember now lol ) on them and the new ones come made from aluminium and the propellor seem different.
Kyle
180 Doctor
PostPosted: Thu Jan 13, 2011 2:35 pm Up
The KWP water pumps from Euro Car Parts come with metal impeller. They also appear to now come with the outlet pipe too which they didn't used to.
