Latest: SA01
Overall: 17138
Online Now [71]:
Visitors: 70
Today: 10482
Total: 111257052
Forums › The Car › 206 Problems › Please help engine fan not cutting in
Mike1987Lee
PostPosted: Tue Jan 11, 2011 5:21 pm Up
Hello Everyone I am new to the board. I was hoping someone might be able to help with a problem I am having.
I took my Peugeot 206 for its MOT and service just after Christmas. Although it has passed its MOT the garage I took it to expressed concern that during the emmissions test there was black smoke coming from the engine. They fitted a new engine cooling fan because the old one had seized. However the fan was not cutting in. I have been informed that the relays have been checked and there is not a problem there . The fuses in the fuse box were checked and none of them had blown. To try to get the fan to start the fuse box was checked but it was different in terms of the fuse size as described on page 148 of the 206 handbook. I have called the customer care centre and was given public.servicebox.peugeot.com/ as a reference for how to find the details however I have only found the exact same information regarding the engine compartment fuse box that is in the handbook. My garage say that I need a wiring diagram and this may be used to identify what is wrong with the car. My question is does anyone here have a copy of the wiring diagram they wouldn't mind emailing or any ideas how I might get one? Has anyone else experienced anything like this?
I apologise if this isn't the right place to post this. I noticed on another topic somone else has a problem with their engine fan but it seems that in their case it was an intermittent fault whereas with mine the fan isn't cutting in at all.
Thank you in anticipation Smile
PostPosted: Tue Jan 11, 2011 5:27 pm Up
Does your car have A/C? If it does, turn it on and the fan should come on too, to keep the engine temp down. I dont see how you could have you could have had smoke coming from your engine though.
Lewis1304
PostPosted: Tue Jan 11, 2011 6:11 pm Up
I have exactly the same problem dude. I googled it found a garage down south who have wrote.
www.petercoopercarrepa..._fan_w.htm
If you call them and as about the part number for the new fan loom, its around £50 if they give you the correct number.
Do try the A/C but my A/C does not kick the fan in either... but I think my gas is gone......
Lewis
206 1.6 16v, Nimrods, Full SP Kit, 3 Stage Valve Cut Head, 4-1 Manifold With Decat, Pug Sport Backbox, Vibe Speakers, HIDs In Projectors, DVD screens & Sub Smile
Navarro206
PostPosted: Wed Jan 12, 2011 3:38 am Up
I had this problem too, but my fan would work fine when I turned the A/C on.
Turns out there was an airlock in the water system which was stopping the thermostat from working (or something like that)
You could try draining the coolant from the lowest point, keeping the reservoir topped up, until you clear the airlock. (Don't forget to add antifreeze again afterwards though, especially at this time of year!)
206 Zest 3
Damo482
PostPosted: Wed Jan 12, 2011 4:07 am Up
I also had this problem but have just fixed it, it was all down to a resistor for me, the resistor wasnt working so the low speed relay couldnt get any power and because the high speed relay only comes on if its really hot, my fan never came on so i replaced the resistor and all is working fine!
Damo
PostPosted: Wed Jan 12, 2011 5:25 am Up
You clear an air lock by venting the air from the highest point.
PostPosted: Wed Jan 12, 2011 6:15 am Up
By using the points in the pipes which lead to the heater matrix.
Navarro206
PostPosted: Wed Jan 12, 2011 7:33 am Up
D'Oh!! Rolling Eyes
206 Zest 3
Mike1987Lee
PostPosted: Wed Jan 12, 2011 2:46 pm Up
Thank you to everyone that has replied to try and help me it is much appreciated. Unfortunately my car doesn't have A/C so that wouldn't be able to trigger the fan for me. I will try to get a Low Speed fan resisitor as Damo has mentioned or try to get the thermostat looked at.
Thanks once again for your replies and I will let you know how I get on
Please help if you can
