Online Now [544]:
Visitors: 543
Today: 100695
Total: 145406434
Forums › The Car › 206 Problems › HELP... COOLANT MYSTERY PROBLEM!
luvpug
PostPosted: Sun Jan 02, 2011 2:07 pm Up
Hi all..
I've got a sloshing water sound coming from my heater matrix when I rev or accelerate...
It all started last month after I found water in passanger footwell, i ignored the sloshing water sound from the matrix (foolish!) then my headgasket went! No doubt the leak from the matrix allowed air into the coolant and blew the gasket! Simple and makes sense.
SO, I then had the new matrix and for a few days all was well. BUT the sloshing sound has returned!! Taken it back to Peugeot twice and they cant understand why there is that sloshing water sound!
No airlock in there
No drop in coolant level
No water leaks
No overheating issues
...its a mystery! Shocked
It just makes a hell of a water sound (like I got a fountain in my glovebox)
when I rev and accelerate from just 2,000 rpm and it SURE AINT NORMAL!
SO... can anyone please out-do a Peugeot technician and explain whats wrong here...????
Luvpug
mjsroofing
PostPosted: Sun Jan 02, 2011 2:09 pm Up
water in matrix box
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
luvpug
PostPosted: Sun Jan 02, 2011 2:55 pm Up
cheers for the reply... how likely is that to be mind (with it being a new matrix n all)?
what problems will that cause?
Luvpug
PostPosted: Sun Jan 02, 2011 3:06 pm Up
did you changed your thermostate with all the things you have done??,if you didn't there is a chance it's a faulty one,i mean it don't close 100%,and don't open 100%,so it's 50-50,which make the coolant cycle not well..
OR
your water Pump is weak,and on it's way to say "bye bye",which also make the coolant cycle not effective,and also may cause a head gasket again.
OR
you radiator is full of dirt which make the water cycle a bad one.
So the three cases all linked to each other,so check them all,and you will solve the mystery,Good Luck.
PostPosted: Sun Jan 02, 2011 3:17 pm Up
All that cycling has worn me out.
luvpug
PostPosted: Mon Jan 03, 2011 9:41 am Up
cheers pal for the ideas there, i've just had a new thermostat, a new water pump and a new coolant.
the sloshing water sound was there before I changed them, and now still after...
still a mystery!
Luvpug
PostPosted: Thu Jan 06, 2011 12:49 pm Up
still a mystery!
well that is good thing,by doing all that,you are elemnate the cause of this mystery,but i see that you didn't check your radiator??why is that?
luvpug
PostPosted: Tue Jan 11, 2011 10:11 am Up
check radiator and just like everything else.. no reason for this problem I'm having!
COME ON... CAN NO ONE HERE HELP WORK THIS ONE OUT!?!
Luvpug
Danny.
PostPosted: Tue Jan 11, 2011 10:15 am Up
Like Someone said Water in Heather Matrix box... This is very likely if you had a leak.
PS: Calm down shouting at us wont make us help any faster infact in most cases it will do the opposite. We will help if we can.
Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
luvpug
PostPosted: Tue Jan 11, 2011 10:27 am Up
No fella Ive had it replaced along with the pipes and since NO leaks.
Luvpug
Danny.
PostPosted: Tue Jan 11, 2011 11:09 am Up
So this is the big Plastic housing the matrix sits in yes?
luvpug
PostPosted: Wed Jan 12, 2011 5:45 am Up
yes
Luvpug
