Online Now [643]:
Visitors: 642
Today: 64790
Total: 146210022
Forums › The Car › 206 Problems › axle woes
axle woes
badj
PostPosted: Thu Jan 13, 2011 12:38 pm Up
I think the rear axle bearing(s) may have gone on my 206.
Its a 99 Gti, and although there doesnt seem to be as much 'camber' as I've suffered from with 306s in the past, one wheel has an awful lot of sidewards play in it (moves in 9 & 3 oclock directions). When driving it randomly starts vibrating the whole car and a mate following said the wheel twitches.
I've assumed that it can only be the axle bearings that are gone Sad
Any had this before?
Iceland Blue '99 206 GTI (140) - SOLD
KMF '05 1.4 HDi
T_bandery
PostPosted: Thu Jan 13, 2011 12:45 pm Up
Is it just the wheel that is moving or is the whole arm moving sideways?
PostPosted: Thu Jan 13, 2011 12:53 pm Up
if only wheel move is wheel bearing, otherwise is the axle bearing
badj
PostPosted: Thu Jan 13, 2011 1:43 pm Up
Just had a drive to tescos and jacked the wheel up - can't really feel movement with the wheel off the ground, with the tyre on the ground it can move - suspect that it is the axle Sad
KMF '05 1.4 HDi
