Online Now [385]:
Visitors: 384
Today: 39844
Total: 127791576
Forums › The Car › 206 Problems › noise when turn :s
noise when turn :s
tiago90
PostPosted: Thu Jan 13, 2011 2:22 pm Up
Everytime i turn, i can here some "clicking " noises . Like if something was hiting or rubbing something else :s
Do you know what it could be ? :s
PostPosted: Thu Jan 13, 2011 2:25 pm Up
topmount bearing?
tiago90
PostPosted: Thu Jan 13, 2011 2:29 pm Up
are they easy enough to replace it myself ? or take it to a garage ?
Junglingo
PostPosted: Thu Jan 13, 2011 2:39 pm Up
CV Joints? check for splits in the gaitors and grease on the inside of your wheels
GTi 180 - Scorpion Exhaust
T_bandery
PostPosted: Thu Jan 13, 2011 2:40 pm Up
easy job if you are handy with spanners
could be drive shaft gaiter which needs replacing
mattievrs
outer cv joint or wheel bearing
NO LONGER ACTIVE ON THE FORUM
pug206lx
PostPosted: Thu Jan 13, 2011 2:41 pm Up
CV joints
tiago90
PostPosted: Thu Jan 13, 2011 2:51 pm Up
so, take it to a garage and get a quote as i dont know a lot about mechanics ? -.-
but im gonna have a look first tomorrow if doesnt rain .
Thanks Smile
pug206lx
PostPosted: Thu Jan 13, 2011 3:07 pm Up
As mentioned look to see if the cv gaiter (one directly on the back of the wheel hub behind the wheel) is split or is loose. sometimes the clips come undone and allow dirt and grit into the joint.
