Latest: sparrowdclxvi
Overall: 17139
Online Now [182]:
Visitors: 181
Today: 6903
Total: 113616051
Forums › The Car › 206 Problems › Car wont turn off! Help!
fkismad
PostPosted: Thu Jan 13, 2011 12:43 pm Up
Need some help. Came home from work today and went to turn my 1.9d off and it wouldnt turn off! had to put it into 3rd gear and stall it!
Any ideas what could be wrong?
thanks
TomMessenger
PostPosted: Thu Jan 13, 2011 12:46 pm Up
Can you take the key out?
www.me-strings.co.uk - Day Job
www.tommessengerphoto.com - Occasional Job
tommessengerphoto.com/page7.htm - Fishy Stuff
wagsy206
PostPosted: Thu Jan 13, 2011 12:48 pm Up
Can you remove the key from the ignition? The reason I ask, my dad had a 406 and he couldn't turn the key to switch the car off. Ended up having to get a new ignition and ignition loom.
Wagsy206
old post count: 5000+
Team: Honda Accord
PostPosted: Thu Jan 13, 2011 12:49 pm Up
burning engine oil i guess
fkismad
PostPosted: Thu Jan 13, 2011 12:56 pm Up
Yeah i can take the key out. It goes back in as well easily.
Francis
LilLew
PostPosted: Thu Jan 13, 2011 1:26 pm Up
sounds like the engine is overfueling i would check the EGR valve & lambda sensor can cause it
disconnect eact one sepearatly and see if it helps
Do you haveany engine warning lights on??
2003 Pug 206 2.0 GTI 180
PostPosted: Thu Jan 13, 2011 1:35 pm Up
Stop solenoid on the diesel pump Wink
fkismad
PostPosted: Thu Jan 13, 2011 1:44 pm Up
Just the battery light is dimly lit. Would the stop solenoid be the first/cheapest option to try ?
Francis
ExoVyper
PostPosted: Thu Jan 13, 2011 1:57 pm Up
What She Said
gti180boy
PostPosted: Thu Jan 13, 2011 2:53 pm Up
I would all so check this first as the solenoid cut the fuel off which turn the engine off.
easy fix aswell Smile
kyle
180 Doctor
kieron
PostPosted: Thu Jan 13, 2011 3:11 pm Up
on the dw8 1.9 it has a lucas fuel pump and the stop solenoid has a anti theft plate around it you have to grind it off and its a nightmare on the car but not impossible as i have done one with a dremmle before here is a pic
Account suspended
fkismad
PostPosted: Thu Jan 13, 2011 3:47 pm Up
Thanks for the replies! Il have a pop at changing the stop solenoid.
Francis
fkismad
PostPosted: Fri Jan 14, 2011 3:59 am Up
Forgot to ask, how do i know if my pump is a lucas or bosch? Ive seen a DW8 engine spec and it says it could be either pump.
kieron
PostPosted: Fri Jan 14, 2011 7:16 am Up
most come with lucas the lucas is the one in the pics above a bosch is the pic below
on a bosch the solenoid is exposed so its easy to get to bosch are very rare on dw8 in the 206 they put them on the 306 dw8 and a few berlingo vans
Account suspended
fkismad
PostPosted: Fri Jan 14, 2011 5:41 pm Up
I had a look and found somebody has already cut the steel cover that hides the solenoid and it looks like a new wire has been added in for some reason. Thought it might be a bad connection so i took the nut of the solenoid and cleaned the contacting metal. This wire doesnt look original at all.
Think i will just replace the soldenoid. Do i need a special tool to take it out ?
Francis
