Latest: tebas93089
Overall: 17179
Online Now [326]:
Visitors: 326
Today: 44651
Total: 137816415
Forums › The Car › 206 Talk › hey guy got a problem with my brakelights....need help!!!
Ruraidh206Brown
PostPosted: Fri Jan 14, 2011 4:27 pm Up
hey guys...my brake lights keep coming on even when im not touching the brake pebal???
Peugeot 206 1.1L
Dabamash
PostPosted: Fri Jan 14, 2011 4:28 pm Up
Staff - Daba
If they stay on, the plug under the steering wheel has come out.
Ruraidh206Brown
PostPosted: Fri Jan 14, 2011 4:30 pm Up
onaww thnks man what does the plug look like?
Peugeot 206 1.1L
T_bandery
PostPosted: Fri Jan 14, 2011 4:46 pm Up
Its a white plug underneath the glovebox, just push it right in!
Dabamash
PostPosted: Fri Jan 14, 2011 4:49 pm Up
Staff - Daba
Ah glovebox, roflmao, my mistake.
Ruraidh206Brown
PostPosted: Fri Jan 14, 2011 4:51 pm Up
yea a just done it thnks guys so much help Smile
Peugeot 206 1.1L
Danw_VVT
PostPosted: Mon Jan 17, 2011 4:34 am Up
mine has the oppisite. from people puting there feet right up under the box it knocks my brake lights out at times
ma.langan
PostPosted: Mon Jan 17, 2011 4:40 am Up
my friends are always pushing my brake switch out and ive been pulled over about 15 times for having constant brakelights on, so to avoid I wired a little LED into the middle brake light and pushed it through the lining on the ceiling inside, so everytime I break i can see the LED and if the switch has been kicked out the LED stays on with the lights! cost me about £2 to do and ive always caught them out when the switch gets kicked!
Farmer T'aaron!
Danw_VVT
PostPosted: Mon Jan 17, 2011 4:48 am Up
i check mine pretty much every day to make sure they arent out as a few times people have flashed me saying i have no brake lights.
MrBombHead
PostPosted: Sat Jan 29, 2011 10:46 am Up
I just failed my MOT as my breaklights (all 3) were not working.
Changed the Fuses first, then bulbs and now just checked this "White connector" and it was plugged in, took it out and reseated and still getting the problem.
I assume this is the area I am supposed to be looking at for this "white plug"
Seems strange that all my break lights have stopped working.
Wonder if this unit itself is faulty, so the connection is not being made when the breaks are pushed.
Any other ideas guys?
Bombhead
My 206 - 206info.co.uk/Forums/v...23351.html
Facebook - www.facebook.com/Bombhead
PostPosted: Sat Jan 29, 2011 10:47 am Up
Try shorting the connector plug out then see if the brake lights come on.
Sounds like it needs a new switch.
MFACTOR001
PostPosted: Sat Jan 29, 2011 10:53 am Up
two brake swithces if that helps one under drivers fuse box and other behind glove box on the end of the brake bar common to get knocked with passangers feet causes rear light faults.
MFACTOR RAP1D HDI
TEAM: NO BASE JUST RAW ENGINE
Tools are cheap experiance is invaluable
I make no appolagies for spelling punctuation
MFACTOR001
PostPosted: Sat Jan 29, 2011 10:55 am Up
staying on could also be an indication that the brake swith on the end of the brake bar has been knocked out.
MFACTOR RAP1D HDI
MrBombHead
PostPosted: Sat Jan 29, 2011 10:59 am Up
Thanks.
Where about is the one under the drivers fusebox? Is it going to be something very easy to spot? or is it mixed in with millions of other cables?
Bombhead
MFACTOR001
PostPosted: Sat Jan 29, 2011 7:49 pm Up
The best way to see it is opem door and sit on floor and stick your head under it is in the middle if you have problems locating follow brake and the other one also view from the floor behind glove box torch might be needed hope that helps.
MFACTOR RAP1D HDI
