![](themes/base/images/spacer.gif) |
![](themes/base/images/titleTL.gif) |
Forums › The Car › 206 Talk › 206 gti 180 water pump housing |
![](themes/base/images/titleTR.gif) |
![](themes/base/images/titleBL.gif) |
![](themes/base/images/titleBR.gif) |
![](themes/base/images/forums/otl.gif) |
Posted: Thu Jan 13, 2011 1:41 pm |
Edward wrote: |
The KWP water pumps from Euro Car Parts come with metal impeller. They also appear to now come with the outlet pipe too which they didn't used to. |
For another £20 or so i would just go genuine and when i do a cambelt change i all ways just fit genuine pug one.
| | ![](images/spacer.gif) |
| 206 Gti 180 Cat-camshafts 804's, Cat cams CTPE 002 exhaust vernier pully, RS tuning remap, Cat back janspeed exhaust, K@N Typhoon induction kit- heat wrapped, Exhaust manifold heat wrapped, Goodridge brake flexi's poly bushs in rear lateral arms, blue led speedo convertion, 50mm Eibach sport line springs, ......
180 Doctor
Hemwoods Gti180 / Pug specialist | |
Posted: Thu Jan 13, 2011 1:43 pm |
I wonder who makes the Peugeot parts....
Posted: Thu Jan 13, 2011 1:46 pm |
Edward wrote: |
I wonder who makes the Peugeot parts.... |
![Smile Smile](images/smiles/icon_smile.gif)
Loads different manufacturers lol the genuine water pump for gti / 180 made by a make i never seen or herd of before lol
180 Doctor
Posted: Sun Jan 16, 2011 10:12 am |
Posted: Sun Jan 16, 2011 1:42 pm |
There's nothing wrong with those KWP pumps, especially the ones with the housing included. Euro Car Parts don't stock junk parts. As GTi180boy says, Peugeot pumps are made by lots of manufacturers so what exactly is a genuine part?
| ![](themes/base/images/forums/otr.gif) |
