Online Now [116]:
Visitors: 116
Today: 25650
Total: 104998593
Forums › The Car › 206 Problems › Another misfiring problem, unsanely difficult to solve!
Go to page Previous  1, 2
gpvecchi
PostPosted: Mon Jan 17, 2011 2:45 pm Up
Fuel regulator is ok, i have 3,5 bar at the injectors; I even thought at coolant sensor, PPS2000 reads "in range" values, but they could be not the real ones...
Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror
PostPosted: Mon Jan 17, 2011 2:49 pm Up
White smoke, using water?
Compression checked it? Could be down on one cylinder
Checked that all the coils are giving sparks?
Had it checked for codes/scanned?
Few ideas to keep you busy
gpvecchi
PostPosted: Tue Jan 18, 2011 3:12 pm Up
No, it's not head gasket and I don't have P codes... Today problem hasn't appeared... So strange...
gpvecchi
PostPosted: Tue Feb 01, 2011 2:14 pm Up
I FOUND IT! The gasket between intake manifolds and engine head had been "sucked" at the inside: I had a very little air leak, but in particular, one piece of the gasket was exactly in front of the 4th injector!
scottbrown444
PostPosted: Sat Feb 12, 2011 7:27 am Up
how do you locate and change the spark plugs
its me a peugeot dude
Page 2 of 2
