Latest: Willy.Sea
Overall: 17168
Online Now [104]:
Visitors: 103
Today: 20780
Total: 128570209
Forums › The Car › 206 Problems › engine immobiliser fault
Go to page Previous  1, 2
darrenskinner1
PostPosted: Tue Jan 04, 2011 12:16 pm Up
ok we got the car back and fixed,
they did diagnostics and every warning showed a fault in the electrics,
they changed some pins within the ecu and for now its resolved the problem,
expensive tho
Snowster88
PostPosted: Sun Jan 16, 2011 4:43 am Up
Hey i had the same problem as this only 2 weeks ago, aswell as engine immobiliser fault it would also say anti pollution fault. i had the AA out twice and a local mechanic take a look at it but none of them could diagnose it. it was still under warranty so i sent it back to the garage i bought it from and they thought it was the chip in the key so they asked me if they could send it back to peugot garage to be fixed and i agreed. Apparently they knew exactly what was wrong with it and found the fault in no time, it was something called a PSF fuse box which had naffed so they replaced it and it has been fine since (fingers crossed) The peugot garage said it was a common fault in some of the 206 models. I'm not saying that's what wrong with yours but just thought it may help Smile
mdstone
PostPosted: Tue Jan 18, 2011 3:37 am Up
Had this fault on mine when I replaced the battery in the car and the key fob. You may need to get the fault cleared from the ECU, Pug did this for me and hasn't come back since.
Peugeot 206 GTi
Page 2 of 2
