Posted: Tue Jan 18, 2011 7:25 am |
yea i would never let mine go that far
| | ![](images/spacer.gif) |
Posted: Tue Jan 18, 2011 7:29 am |
i found this, scroll to the bottom. its says 80,000km so thats about 50,000 miles but its an aus one so not sure if that makes a difference
www.peugeot.com.au/med...d0f042.pdf
Posted: Tue Jan 18, 2011 7:32 am |
yea raj same as the guys are saying cheers mate
Posted: Tue Jan 18, 2011 7:36 am |
they are saying 80,000 MILES, the link say 50,000 MILES (which is 80,000km) so not sure :s
Posted: Tue Jan 18, 2011 7:40 am |
cool im jus gonna do it
Posted: Tue Jan 18, 2011 8:07 am |
I rang Peugeot last year when I bought the car. They said 80K or 10 years. Mine is a 52 and when I bought had 82K, so knocked a bit off the price. Had mine done soon after.
Posted: Wed Jan 19, 2011 8:07 am |
According to the Autodata book (which the garages use), Peugeot recommend the belt is changed every 80,000 miles under normal conditions, 48,000 miles under adverse conditions. It also says that the 206 engines are 'interference engines', which means that if the belt breaks the possibility of valve-to-piston damage is 'most likely'.
Basically, if you've been giving your engine a hard time the recommended interval is 48,000.
For the cost of doing the job, it's certainly a good idea to get it done if you're worried / suspicious about the belt condition, especially as the damage done by a belt breaking will be expensive...
(Just for the record, the Autodata book I'm looking at is the 2002 edition, which may well be out of date by now. If anyone has seen anything different please let us know!)
Posted: Wed Jan 19, 2011 3:08 pm |
mine's being replaced soon, getting the garage to replace water pump and timing belt, less than £290 supplied and fitted
Posted: Thu Jan 20, 2011 4:51 am |
cool mate
im gettin absoutley everything done, i work at mercs so one of the techs will do it, cheap as chips lol
so all ready for the long drive to all the shows next year woo
