Latest: jackrox1992
Overall: 17186
Online Now [367]:
Visitors: 366
Today: 51936
Total: 148587843
Forums › The Car › 206 Problems › Gti handbrake light
Gti handbrake light
supacook2k
PostPosted: Thu Jan 20, 2011 4:48 am Up
When going around a roundabout or a sharp bend the handbrake light flickers until I come off the roundabout or bend. Anyone have any ideas on what is causing this?
206 gti 1999
PostPosted: Thu Jan 20, 2011 5:07 am Up
Low brake fluid.
dturbopeck
PostPosted: Thu Jan 20, 2011 5:10 am Up
brake fluid is low.
dturbopeck
brake fluid is low.
pat_986
PostPosted: Thu Jan 20, 2011 5:11 am Up
What they said
2004 Flamenco red GTi 180
sillyhilly
PostPosted: Thu Jan 20, 2011 5:13 am Up
OR your pads are getting low
Hi Mikey Smile
supacook2k
PostPosted: Thu Jan 20, 2011 5:17 am Up
Cheers guys. I'm having my brake pads done on the weekend. So the brake fluid will be checked then.
206 gti 1999
PostPosted: Thu Jan 20, 2011 5:19 am Up
True.
supacook2k
PostPosted: Thu Jan 20, 2011 6:15 am Up
Are the rear brakes easy to change? I'm having the front done this weekend. I read before that special tools are required for the rear brakes. I'm having a friend do them who used to be a mechanic.
206 gti 1999
PostPosted: Thu Jan 20, 2011 6:18 am Up
No, you just need some long nose pliers or a long, flat headed screwdriver to wind the piston back in.
PostPosted: Thu Jan 20, 2011 6:45 am Up
Does the STOP warning light come on at the same time?
benb
PostPosted: Thu Jan 20, 2011 7:41 am Up
check the handbrake button under the handbrake
1.1lx 2000 plate
supacook2k
PostPosted: Thu Jan 20, 2011 7:05 pm Up
nope. just the handbrake light
206 gti 1999
PostPosted: Fri Jan 21, 2011 5:50 am Up
Check the handbrake switch & wiring then, as a test swop it for the glovebox light switch as there exactly the same part Wink
