Latest: S2cgm
Overall: 17178
Online Now [113]:
Visitors: 111
Bots: 2
Today: 41599
Total: 137471093
Forums › The Car › 206 Problems › Speedometer Back Light
Sorelini
PostPosted: Thu Jan 20, 2011 9:20 am Up
Hey,
I've searched through the posts the best I could so sorry if i am repeating a prior post!
The speedometer on the dash all works fine but when i switch my lights on the backlight doesn't come on, this makes driving at night a 'mare as i cant see how fast im going!!
Has anybody else had this issue? I think it may be a fuse but have no idea which one, I'm going to buy a Haynes manual at the weekend but until then any ideas? The glovebox light is also not working Sad
Car is a 2000 Hdi 2.0
Thanks!
ukskater01
PostPosted: Thu Jan 20, 2011 9:27 am Up
Sounds like a fuse, have a look at the fuses under the steering wheel. If any have popped replace them
good luck
Sorelini
PostPosted: Thu Jan 20, 2011 10:33 am Up
will check tonight,
cheers!
Sorelini
PostPosted: Thu Jan 20, 2011 10:47 am Up
Just had a look and I dont have the manual at hand, does anybody know which fuse it is?
Really need this Haynes manual at the weekend!! Embarassed
elcamino
PostPosted: Thu Jan 20, 2011 2:32 pm Up
check this: fuse is there anything else not working other than that?
el camino. "Whether you think you can or you think you can't, you're right" Henry Ford.
Sorelini
PostPosted: Thu Jan 20, 2011 2:36 pm Up
cig lighter, centre console lights and glove box light Sad
elcamino
PostPosted: Thu Jan 20, 2011 2:41 pm Up
Pls. check if your number plate and side lights fine?
Sorelini
PostPosted: Thu Jan 20, 2011 2:43 pm Up
yep those all work fine
thanks
elcamino
PostPosted: Thu Jan 20, 2011 2:47 pm Up
Ok.what about fuse?i think u should chk. no. 22
Sorelini
PostPosted: Thu Jan 20, 2011 2:49 pm Up
will do,
thanks for the advice, what order does the fuses count top left to top right and then down a row?
Cheers!
Sorelini
PostPosted: Fri Jan 21, 2011 12:49 pm Up
anybody?! or a pic of the fuse layout from the manual would be uber appreciated!
elcamino
PostPosted: Fri Jan 21, 2011 2:36 pm Up
Numbers are written.but its better to check all the fuses.although i think its not a melted fuse....
Sorelini
PostPosted: Sat Jan 22, 2011 5:16 am Up
cheers will check them all, bought a load of spares this morning
ma.langan
PostPosted: Sat Jan 22, 2011 5:51 am Up
that sounds like fuse f15 or f20 one or the other (inthink) but it will probably vary
Farmer T'aaron!
Sorelini
PostPosted: Thu Jan 27, 2011 11:13 am Up
Okay i changed the fuses in F22 and looked at all the others, and they are fine, but nothing has been restored!
things that are not working (that i have noticed) are:
Speedometer back light
number plate lights (only just noticed that was out after checking everything)
panel below the stereo - all buttons have no back light
glove box light.
could it be possible all the bulbs have gone?
Cheers!
