Latest: cogeim7
Overall: 17185
Online Now [845]:
Visitors: 844
Today: 193587
Total: 147474565
Forums › The Car › 206 Problems › Coil Pack - Black or Grey?
alexhodge1234
PostPosted: Fri Jan 21, 2011 4:32 am Up
Need a new coil pack.
The original one I had on there was a Grey one but that got replaced with a Black one.
Whats the difference between the two?
Cheers in advance
Alex Hodge
PostPosted: Fri Jan 21, 2011 4:34 am Up
Different brand?
alexhodge1234
PostPosted: Fri Jan 21, 2011 4:41 am Up
No idea, the grey one is long gone now. Ill have a look at what make the Black one is this weekend.
Which is the best brand to get?
Alex Hodge
PostPosted: Fri Jan 21, 2011 4:44 am Up
just stay away from Sagem.. ideally a genuine one from pug or a valeo one from eurocarparts for example.
alexhodge1234
PostPosted: Fri Jan 21, 2011 4:51 am Up
Also just a quick one what size tool should i get to replace the spark plugs? Is it 5/8"?
Alex Hodge
PostPosted: Fri Jan 21, 2011 5:53 am Up
Fit a genuine Bougicord coil pack along with Bosch Super Plus spark plugs.
The 2 different colours of connector plug is simple, some 206's come with a grey plug & others come with a black plug, you match the colour of plug on the coil pack to what is fitted on the car.
alexhodge1234
PostPosted: Fri Jan 21, 2011 6:17 am Up
What size socket do i need to remove the spark plugs?
Alex Hodge
PostPosted: Sun Apr 28, 2013 5:11 am Up
Is this definate Mr.B?
Do you mean if the loom connector is gray it has to plug into a gray socket version on the coilpack?
PostPosted: Sun Apr 28, 2013 5:42 am Up
Not sure if it's 16mm. Also, get a spark plug socket with the rubber insert as it makes life easier when taking them out, and then trying to reseat the new plug onto the thread. Last thing you want to do is cross thread them.
I also found a flexible extension made life easier on my TU3 lump.
PostPosted: Sun Apr 28, 2013 6:35 am Up
Sorry Macca, this thread is a couple of years old and I dug it up by using the search button. Shocked
No idea about the coilpack connector colour?
Mine was changed at some point and not sure the correct one has been fitted. SB says 5970.A8.
PostPosted: Sun Apr 28, 2013 8:17 am Up
Ah well, the information may still come in handy for someone if they use the search to find out about changing spark plugs.
