Online Now [1275]:
Visitors: 1274
Today: 224728
Total: 148979928
Forums › The Car › 206 Problems › ABS faults
ABS faults
kianbach
PostPosted: Sat Jan 22, 2011 9:10 am Up
Right hand rear wheel sensor signal fault - coherence.
Anyone know what this could mean?
Fitted new hubs and sensors this morning.Can clear fault with PP2000 but as soon as wheels turn it comes back.MOT in less than 2 weeks and it's a fail.Car too good to scrap 52 plate HDI 2.0
52 2.0 hdi
PostPosted: Sat Jan 22, 2011 9:46 am Up
2 types of ABS sensor & pickups used, parts are not interchangeable.
Are the replacement parts an exact match for the original parts?
Is the airgap for the sensor set correctly?
kianbach
PostPosted: Sat Jan 22, 2011 11:40 am Up
I changed the rear axle and i think the axle i got was preplex but the car is multiplex so i changed hubs and sensors for multiplex but the gap seems different on both sides but i thought the sensors weren't sided.Looks like an expensive trip to Peugeot dealer to sort Sad
52 2.0 hdi
PostPosted: Sat Jan 22, 2011 11:43 am Up
Try adjusting the right hand wheel sensor so the air gap matches the one on the other side.
kianbach
PostPosted: Sat Jan 22, 2011 12:26 pm Up
how do i adjust it?
52 2.0 hdi
kianbach
PostPosted: Sun Jan 23, 2011 1:29 pm Up
SORTED!! Swapped left and right over no more abs fault...
MOT this wk.
52 2.0 hdi
skard
PostPosted: Wed Jan 26, 2011 3:17 pm Up
same fault has just appeared on my friends 55 reg 2.0hdi - with the front offside sensor being the culprit.
is it a 2 minute plug and play job with a new sensor? i can clear the fault myself.
PostPosted: Wed Jan 26, 2011 3:22 pm Up
First check the toothed ring isnt broken on the driveshaft.
If the ring is cracked / broken it will flag up a sensor fault.
Peugeot main dealer if you actually need a new sensor, sensors are shockingly cheap for multiplexed 206's Wink
skard
PostPosted: Wed Jan 26, 2011 3:27 pm Up
yeh i told her if need be, to get the part from pug as i believe it is about £30?
will probably be done at a garage in the morning as i don't have the time for a few days, and understandably she doesn't like a flashing STOP sign with two kids in the car!
kianbach
PostPosted: Thu Jan 27, 2011 2:16 am Up
Ran mine with flshing stop sign from last July until last week.
Failed Mot on driver's side wishbone and headlamp bulb:( Going into w/shop (I work at Main VW/Audi/Seat/Mits/Mazda dealership) tomorow for wishbones and retest.
52 2.0 hdi
