Latest: airmastertapes
Overall: 17133
Online Now [656]:
Visitors: 655
Today: 103026
Total: 106636610
Forums › The Car › 206 Problems › Refit Headlight Levelling Motor
Pablodius
PostPosted: Sat Jan 22, 2011 5:55 am Up
I bought a 206 a few months back but it was missing the headlight levelling motors for both headlights. I've bought the motors online but can't fit them correctly - as soon as I apply any pressure to the socket the headlight just falls forward into the headlight unit.
I've removed the headlight bulb itself and have tried reaching through into the unit to apply pressure from the other side but nothing seems to work. Have also tried heating the socket and the ball joint on the levelling motor to make the plastic more malleable but again no luck.
Has anyone successfully performed this procedure before? Hope you can help.
Paul
PostPosted: Sat Jan 22, 2011 6:01 am Up
You have to screw the adjuster so it's fully extended. Then you have to silde it in the recess from the side.
It's pretty tricky & I snapped one of the ball joints off Mad
Pablodius
PostPosted: Sat Jan 22, 2011 8:14 am Up
It worked! I never noticed you could manually extend the joint. I can't thank you enough I've been trying this for ages and couldn't find any info online about it. Cheers! Smile
Paul
