Latest: Beduff1977
Overall: 17134
Online Now [621]:
Visitors: 620
Today: 33619
Total: 108849631
Forums › The Car › 206 Problems › Date, Time, Temp display keeps cutting out
Aussiebird
PostPosted: Sat Jan 22, 2011 1:52 pm Up
Hi,
Recently purchased a 2003 206 and really love it. Only problem is that when the weather worsened in November the date, time and temp display kept cutting out. I took it back to the dealer I got it from with no joy. Has anyone else had this problem and managed to get it fixed?
Thanks for your help!
littlebluecar
PostPosted: Sat Jan 22, 2011 1:53 pm Up
might be a dodgy pin, its causes it to look off at times when its dislodged.
is it this display?
www.206info.co.uk/Foru...ppt30.html
edit: actually sorry, your 2003 car wont have this.
what do you mean cutting out? Just display not showing for a while then coming back when it wants?? checked the connections etc?
Aussiebird
PostPosted: Sun Jan 23, 2011 4:07 am Up
Hi DJ,
The display does look very similar to the one you posted. I would have thought that if it was a connection problem that the garage would have found it but you never know!
The display comes on but has reset almost every time you start the car and then will cut out after about half an hour or so of driving. Very annoying!
Tiff
littlebluecar
PostPosted: Sun Jan 23, 2011 9:41 am Up
Hmm not sure as far as im aware it would only reset if the battery is disconnected or if the wire to the unit was not in properly thus when driving would cause it to cut out.
I suggest taking off the cover around the display by just pulling it up from behind until it unclips then take a look at the connection to the display.
is it this one you have?
img7.imageshack.us/img...3/duzy.jpg
Aussiebird
PostPosted: Sun Jan 23, 2011 12:19 pm Up
Hi DJ,
No - I think the ones you have posted might be a touch newer than mine (!) but it does seem to have all the signs of a loose wire.
Will have a look and see what I can find.
Tiff
littlebluecar
PostPosted: Sun Jan 23, 2011 12:23 pm Up
Hey, Ah if you get a picture up that would help as im not sure of which other type display has temp, date and time unless im having total brain freeze today Laughing
Cool, let us know how you get on Smile
