Online Now [383]:
Visitors: 383
Today: 10241
Total: 142393090
Forums › The Car › 206 Problems › 1998 2.0 DTurbo Exhaust
SteveM
PostPosted: Mon Jan 24, 2011 2:09 pm Up
Right, I'm screwed!
Exhaust started blowing this morning and having popped in to those lovely lads at Kwik Fit it seems I need a whole new exhaust.
£404 fitted Crying or Very sad
Anyone know where I can get one on the cheap (2nd hand, whatever). It appears that for this model of car it comes as a complete part.
Please, please, please help me!!!
206 2.0 D Turbo (V)
PostPosted: Mon Jan 24, 2011 2:11 pm Up
Try a DECENT exhaust place Wink
Kwik fit are expensive as they work on a bonus scheme Wink
Local motor factor, Euro car parts or GSF will sell you the parts.
2Oh!6
PostPosted: Mon Jan 24, 2011 2:12 pm Up
GSF ftw.
VTEC goes BWAAAAAAH! Wink
Rob2859
PostPosted: Mon Jan 24, 2011 2:14 pm Up
kwik fit are proberbly lying. Take it to a decent garage as already said. you will find its proberbly just a backbox or something minor
meady
Trade Rating: +45
u could get a nice custom made stainless steel one for less than tht, and you will never have to worry bout replacing it again
TEAM - I HATE FACEBOOK Smile
SteveM
Couldn't find it on the GSF website, only smaller engine models.....
Anyone able to point an amateur to it please?
206 2.0 D Turbo (V)
SteveM
PostPosted: Mon Jan 24, 2011 2:16 pm Up
No, definitely not. I got under to have a check and its broken off just before the back box and there is a hole in the bit in the middle of the car that the pipe runs from to the back box.
All completely unweldable due to rust Sad
206 2.0 D Turbo (V)
MrrNoName
PostPosted: Mon Jan 24, 2011 2:34 pm Up
kwik fit suck, they are so over priced! i got a new one fully fitted for a third of that on my 1.4 Razz deffo try another garage!
SteveM
PostPosted: Mon Jan 24, 2011 3:12 pm Up
What about this...?
cgi.ebay.co.uk/PEUGEOT...1587wt_905
206 2.0 D Turbo (V)
Rob2859
PostPosted: Mon Jan 24, 2011 3:21 pm Up
then you just need a new centre pipe unless it snapped on the backbox too. the cat and front pipe should be fine. even if you replace the front pipe as well the cat will not need replacing until it fails the mot.
SteveM
PostPosted: Mon Jan 24, 2011 3:31 pm Up
Hi Rob,
Using my limited powers of explanation, there is a box at the rear that sticks out the back of the car (A), A pipe that runs from it down the centre of the car (B) and a box towards the front of the car that the pipe connects to (C).
From the front of the system backwards..... there is a hole in C, C connects to B fine but B is completely detached from A at the point where the two meet.
206 2.0 D Turbo (V)
Lewis
PostPosted: Mon Jan 24, 2011 3:34 pm Up
Just do the cheeky trick, beans tin, Gun Gum exhaust tape can get it from most places even halfords, and 3 jubilee clips!
Tivoli LX 1.1
Black GTI 180
White VXR Burg
eddrj
PostPosted: Mon Jan 24, 2011 3:35 pm Up
what that is a real p**s take def be cheaper any other place surely, can get new backbox for £35 ebay new duno how much is middle part though aswell def should be half that price at a good cheaper place
Old car 2000/ 206 2.0 hdi.
adam_16v
PostPosted: Mon Jan 24, 2011 4:10 pm Up
Try www.buypartsby.co.uk/
Very cheap and usually have most exhaust parts.
a
Rob2859
PostPosted: Mon Jan 24, 2011 8:18 pm Up
[quote="SteveM"]Hi Rob,
[quote="Rob2859"][quote="SteveM"]
A = front pipe
B = centre pipe
C = Backbox
Before the front pipe is the CAT; this is pretty expensive but proberbly will not need replacing. You are saying the backbox has come off the rear end of the centre pipe. It is proberbly down to the clamp rusting away rather than the hole pipe breaking off.
So in short you need a front pipe and backbox
Posibly a centre pipe and proberbly not a CAT.
Unless the centre pipe has recently been done you are proberbly better of replacing all of it AFTER the CAT. The CAT is by far the most expensive part of the lot so make sure that is not replaced if it doesn't need to be. I suggest buying the parts and taking it to a good garage to have them fitted.
