Online Now [384]:
Visitors: 383
Today: 5699
Total: 104978723
Forums › The Car › 206 Problems › battery problem
battery problem
jargti
PostPosted: Tue Jan 25, 2011 9:26 am Up
hello to all. I have got a problem but i no what it is but not sure if can do anything about it.
Iv got a 206gti 140 and the positive to the battery is a little lift up clip to disconnect it good idea in theory. but when im driving hard its tends to work loose then when i have stoped turned engine off, try to start again its dies, look under the bonnet and the clip has worked itself loose! so then put it back on the off i go. Is there any way you can get the old stye with wit a 12mm nut and thread to hold it on or am i just going to have to live with it?
Any help would be excellent Smile
French gti\'s all the way Smile
smiddies
PostPosted: Tue Jan 25, 2011 9:45 am Up
easily change it, snip it then wire up the new one, or you can find out why its doing it!!! most probably because its an aftermarket battery, where the terminals are a little lower then orignal!! if you cut out the black plastic to ensure a tight fit for the positive, it will work fine!!
jargti
PostPosted: Tue Jan 25, 2011 10:05 am Up
thats what the 1st thought. i saw that the plastic was to high and it wasnt sitting right, so i cut more of the plastic out and thought i solved the problem but it did it again. bit i will looking at just changing the connector. just but off the existing one and then find the other style. cheer for the help
sp5flys
PostPosted: Sat Jan 29, 2011 3:25 am Up
i had the same problem it came loose every time i started it, what i done was the clip (quick release) on the battery pushed it down as far as i could i used a bit of wood was able to add more pressure then clip the quick release it should click
Hope it help
sp5flys
.. Peugeot 206 2.0 D turbo hdi ..
PostPosted: Sat Jan 29, 2011 5:44 am Up
Never had a problem with the quick release clip, a small amount of foil wrapped around the the + battery terminal should make the clip fit tighter.
Think yourself lucky Peugeot no longer fit the w***y screw on earth connections to the battery, they where seriously s***e! Laughing
