Online Now [516]:
Visitors: 515
Today: 52973
Total: 105316246
Forums › The Car › 206 Problems › what engine do i have?
graham_foley69
PostPosted: Wed Jan 26, 2011 7:58 am Up
I have a 2001 on a y reg 1.4. Is it preplex or multiplex. also is it kfw or kfx. Any help is much appreciated. If it helps the dipstick is on th left.
its broke again
PostPosted: Wed Jan 26, 2011 8:01 am Up
It's non-plexed.
And look at the 6th, 7th and 8th letter of your VIN number for the engine code.
graham_foley69
PostPosted: Wed Jan 26, 2011 9:08 am Up
So am I right in sayin that the engine code has nothin to do with whether its preplex or multi. Also is the position of the dipstick relevant. I have found an engine with same code and from same year so it will fit yeah?
its broke again
dturbopeck
PostPosted: Wed Jan 26, 2011 9:19 am Up
if its got the same code it will fit.
PostPosted: Wed Jan 26, 2011 9:25 am Up
KFW - 1.4 8v EEC 95 depoll engine (TU3AF lump)
KFX - 1.4 8v EEC 2000 depoll engine (TU3JP lump)
The KFW was introduced in order to meet new emission levels [level 4 i think]. It also has a bigger compression ratio 10.5:1 [vs 10.2:1 on the other]. It uses a Sagem S 2000 ECU as well.
Yeah if you get one with the same engine code and year it should fit.
graham_foley69
PostPosted: Wed Jan 26, 2011 9:37 am Up
Will I need the ecu reset as engine management light is on. Also can u tell the engine code just by lookin at engine?
its broke again
PostPosted: Wed Jan 26, 2011 10:25 am Up
Yep.
Dipstick on the left=KFW
graham_foley69
PostPosted: Wed Jan 26, 2011 11:11 am Up
There seems to be a lot of engines for sale advertised as kfw with dipstick on the right. Any ideas?
its broke again
PostPosted: Wed Jan 26, 2011 11:30 am Up
Nope.
