Posted: Wed Jan 26, 2011 7:58 am |
I have a 2001 on a y reg 1.4. Is it preplex or multiplex. also is it kfw or kfx. Any help is much appreciated. If it helps the dipstick is on th left.
| | ![](images/spacer.gif) |
Posted: Wed Jan 26, 2011 8:01 am |
It's non-plexed.
And look at the 6th, 7th and 8th letter of your VIN number for the engine code.
Posted: Wed Jan 26, 2011 9:08 am |
So am I right in sayin that the engine code has nothin to do with whether its preplex or multi. Also is the position of the dipstick relevant. I have found an engine with same code and from same year so it will fit yeah?
Posted: Wed Jan 26, 2011 9:19 am |
if its got the same code it will fit.
Posted: Wed Jan 26, 2011 9:25 am |
KFW - 1.4 8v EEC 95 depoll engine (TU3AF lump)
KFX - 1.4 8v EEC 2000 depoll engine (TU3JP lump)
The KFW was introduced in order to meet new emission levels [level 4 i think]. It also has a bigger compression ratio 10.5:1 [vs 10.2:1 on the other]. It uses a Sagem S 2000 ECU as well.
Yeah if you get one with the same engine code and year it should fit.
Posted: Wed Jan 26, 2011 9:37 am |
Will I need the ecu reset as engine management light is on. Also can u tell the engine code just by lookin at engine?
Posted: Wed Jan 26, 2011 10:25 am |
graham_foley69 wrote: |
Also can u tell the engine code just by lookin at engine? |
Yep.
Dipstick on the left=KFW
Posted: Wed Jan 26, 2011 11:11 am |
There seems to be a lot of engines for sale advertised as kfw with dipstick on the right. Any ideas?
Posted: Wed Jan 26, 2011 11:30 am |
There seems to be a lot of engines for sale advertised as kfw with dipstick on the right. Any ideas? |
Nope.
