Latest: tbafonso
Overall: 17130
Online Now [320]:
Visitors: 320
Today: 41833
Total: 104231478
Forums › The Car › 206 Talk › WTF
WTF
stevedude
PostPosted: Thu Jan 27, 2011 9:14 am Up
Jay794 wrote:
Fixed my problem, but then there were a couple of other things wrong with mine when I got the eco mode message
such as?
Happydays
Jay794
PostPosted: Thu Jan 27, 2011 9:23 am Up
I needed a new battery?
PostPosted: Thu Jan 27, 2011 9:26 am Up
Jay794 wrote:
CD-vRS wrote:
Jay794 wrote:
There was a few threads about this on the old Info site. It just means there's a problem with your car, get the fault codes read or a good service, that should fix it. FYI, I'm still trying to find the Veyron button on my car
Incorrect.
The car goes into Eco mode to save the battery so there is enough charge to start the car.
Eg if you're sitting in the car with the radio on for 20 mins or so the car will go into eco mode & disable some functions such as the radio & lights.
How is that incorrect? surely if your battery is low on power that is classed as a problem?
It is incorrect Rolling Eyes
The BSI is programmed to stick the car in economy mode after a certain amount of time ( setting changeable with Peugeot planet, 15 minutes is the latest Peugeot main dealer setting ) no matter how good the battery is, you could have the car hooked up to the biggest 12 volt battery known to man, the BSI wont care it will still time out & put the car in to economy mode.
NICKST
PostPosted: Thu Jan 27, 2011 9:27 am Up
apjs87 wrote:
CD-vRS wrote:
Incorrect.
THIS
As above there are no faults with your car.
Junglingo wrote:
there is no by-pass for this feature, which is annoying, but it saves your battery dying if you leave your lights on.
You can turn it OFF in the BSI configuration set up with Peugeot Planet Wink
NICKST
PostPosted: Thu Jan 27, 2011 9:30 am Up
Even needing a new battery wouldnt bring Eco mode up as a fault because (it's not a fault)
PostPosted: Thu Jan 27, 2011 9:31 am Up
What She Said
Exactly, its a designed in feature of the car that is explained in the owners manual ( when people actually bother to read it Rolling Eyes )
Jay794
PostPosted: Thu Jan 27, 2011 9:32 am Up
Yeah but I had a couple of anti pollution faults that needed fixing too, hence getting the fault codes read and having a service uncovered a load of other problems that were fixed
stevedude
PostPosted: Thu Jan 27, 2011 9:33 am Up
Mmmm ok ill ignore it
Happydays
NICKST
PostPosted: Thu Jan 27, 2011 9:35 am Up
These would of had nothing to do with Eco mode tho.
stevedude
PostPosted: Thu Jan 27, 2011 9:39 am Up
MrBSI wrote:
well this person looked in manual and it dont say s**t about it
Happydays
There's nothing wrong with your car, it's just doing something PSA Peugeot / Citroen designed the software to do Wink
NICKST
PostPosted: Thu Jan 27, 2011 9:45 am Up
This is how you fix it. Don't leave you stereo ,lights or enything else on while the engine isnt running and it wont do it. Wink
PostPosted: Thu Jan 27, 2011 9:47 am Up
stevedude wrote:
ECONOMY MODE FUNCTION
After the engine has stopped, with
the key in the accessories position,
certain functions (windscreen wiper,
electric windows, courtesy lights,
audio equipment etc.) can only be
used for thirty minutes, to prevent
discharging the battery.
Once the thirty minutes are over, the
message "Economy mode active"
appears on the multifunction display
and the active functions are put on
standby.
A flat battery will prevent the engine
from starting.
It's on page
104
Or
131
Or
132
Or
140
Or
161
Or
150
Or
156
Or
158
Depending on what version of the handbook your car has Wink
stevedude
PostPosted: Thu Jan 27, 2011 9:52 am Up
lol not in mine it aint, just checked
its only got 147 pages, none missing either
45.02.01 anglais
Happydays
Page 2 of 3
