Latest: tebas93089
Overall: 17179
Online Now [119]:
Visitors: 118
Today: 21530
Total: 138387404
Forums › The Car › 206 Talk › Steering wheel
Steering wheel
chris_rock206
PostPosted: Wed Jan 26, 2011 6:14 pm Up
hi there was just wondering if a gti steering wheel can do a swap with a 1.4 steering without any hassel just old one out new one in simple. Or is there different things that goes with gti steering wheel like i noticed the horn is on the side stick so how would that work lol
PostPosted: Wed Jan 26, 2011 6:19 pm Up
As long as its from a MUX GTi it will
bellevuespares
PostPosted: Wed Jan 26, 2011 6:33 pm Up
someone was asking me this earlier today, i have 2 GTI phase one's 1999 models, and he was wondering if it would fit 2003 1.4
I did look for Lee but he wasnt around, But i came across a COPY Lee named (Lee.) I nearly mailed him until i seen he had only 1 rating then i knew it wasnt you.
Sig removed due to size
PEUGEOT 206 & FIAT PUNTO Replacement Parts at Bellevue Spares Manchester.
We also offer a fitting service! Free Quotes!
PostPosted: Wed Jan 26, 2011 6:39 pm Up
Non-plexed use a bolt on airbag, whereas mux use a clip on airbag
They are interchangeable within the same electrical system.
bellevuespares
PostPosted: Wed Jan 26, 2011 7:04 pm Up
So basically if the airbag is supplied with the steering wheel it is interchangable without a doubt?
Do they have the same size column (diameter) for the Wheel to sit into.?
PostPosted: Wed Jan 26, 2011 7:08 pm Up
No, you need to use a non-plexed steering wheel on a non-plexed car. Same with mux.
So yours will only fit upto like a Y-reg (2001)
bellevuespares
PostPosted: Wed Jan 26, 2011 7:11 pm Up
Im with you. I done it all right, Advertised as 98-01
chris_rock206
PostPosted: Wed Jan 26, 2011 7:52 pm Up
Mate you have just well lost me now :L mines an 04 model so is there any that would just fit in without any hassel or do you needa change something else Razz
sorry if i sound like a complete noob :L
PostPosted: Thu Jan 27, 2011 10:18 am Up
You need a MULTIPLEXED / CLIP ON airbag type steering wheel Wink
Multiplexing came in on the 206 from late 2001.
You also use your original airbag with the leather wheel, it's the same fit across the multiplexed 206 range.
Be warned: A non plexed / BOLT ON airbag type wheel is NO GOOD for your car!
chris_rock206
PostPosted: Thu Jan 27, 2011 11:53 am Up
ryt get ya now chum Razz so i can take out my airbag and stick it into one that doesnt also i seen on ebay people sayin the later models only have a bolt at 6.30 instead of one at 3 and 9 is this true?
PostPosted: Thu Jan 27, 2011 11:59 am Up
Airbag is clipped on for the multiplexed wheel, as long as its the clip on type multiplexed wheel it will fit.
The only thing at 6.30 is the slot on the back of the wheel to release the clip Wink
chris_rock206
PostPosted: Thu Jan 27, 2011 12:08 pm Up
ryt ns i'll have a look l8er cheers mate Very Happy
PostPosted: Thu Jan 27, 2011 12:10 pm Up
Shut BSI down correctly then wait 10 minutes before you unplug the drivers airbag.
That allows the airbag system back up capacitors to discharge.
chris_rock206
PostPosted: Thu Jan 27, 2011 12:19 pm Up
yeah read that somewere else will i just disconnect the battary leave it for 10 mins then do it then take the airbag out have a nosy then plug the barrary bk in leave it 10mins then i can start the car.
