Latest: cogeim7
Overall: 17185
Online Now [375]:
Visitors: 374
Today: 102912
Total: 147229729
Forums › The Car › 206 Talk › 180 wouldn't start this morning
Forum Index › 206 Talk
Lee180
PostPosted: Fri Jan 28, 2011 2:33 am Up
Went to my car this morning, -3 degreese , turned ignition on and everything worked, the cd player, climate cotrole, wipers, lights everythign. Then as usual I tried to start the car and it wouldn't even try start, couldn't hear anything happening, after a while and a few screams at the dash board it starts, any ideas ? Didn't know If this was a feature to let somthing warm up ? Thanks in advance
Originate, don't duplicate.
Big_Rich180
PostPosted: Fri Jan 28, 2011 2:40 am Up
Battery on its way out?
Lee180
PostPosted: Fri Jan 28, 2011 2:45 am Up
Nope, brand new battery last week if it was the battery it wouldn't have started at all but it did after I left the ignition on for a while plus the 180's go into Eco mode when the battery is going low so surely it would have given me some indication the battery was low
Cheers for the reply anyway
Big_Rich180
PostPosted: Fri Jan 28, 2011 2:47 am Up
Maybe it was just having a nob head morning like mine does so often lol.
Lee180
PostPosted: Fri Jan 28, 2011 2:49 am Up
Sounds about right for a French piece of s**t......
But we all love em
NICKST
PostPosted: Fri Jan 28, 2011 3:13 am Up
Lol
Did the engine turn over?
Lee180
PostPosted: Fri Jan 28, 2011 3:25 am Up
Nope she isn't even turn over
jamiea69
PostPosted: Fri Jan 28, 2011 3:33 am Up
the temperatures can very be very harsh on the poor pug, my engine sounds like a tin can in the mornings when i start it
225 cupra r
wull
possibly a problem with the starter solenoid or the starter itself.only way to be absolutely sure about this would be to test for voltage at the starter motor when the key is turned.
next time it happens you can also bridge the connections at the solenoid and this should crank the engine over and start it.this will indicate that there is a problem with solenoid itself.
2000 gti
dturbopeck
PostPosted: Fri Jan 28, 2011 3:57 am Up
sounds like a starter fault starting, inlet manifold off to do am sure
jeoff82
PostPosted: Fri Jan 28, 2011 4:28 am Up
You need to check the amperage at the starter not volts
CFC
Lee180
PostPosted: Fri Jan 28, 2011 4:56 am Up
But surley if it was something to do with the starter, it would of happened more than once ? Now it turns on fine ect ect ect. I think the french piece of s**t put up his white flag this morning :L then decided to work later on (: the joys of owning a peugeot <3
Ali_H
PostPosted: Fri Jan 28, 2011 5:47 am Up
Might be the immobiliser, my mates does it every so often.
kurtis wrote:
DeadEyePaul
PostPosted: Fri Jan 28, 2011 5:56 am Up
mine does this, turn the key... chug chug chug doesnt start. stop remove key, try again.. starts 1st time
Lee180
PostPosted: Fri Jan 28, 2011 12:15 pm Up
funny you should say that, asoon as i hit the alarm button it started, i dont know if it was coincidence or not.
